asylum Posted December 5, 2012 Share Posted December 5, 2012 To whom are used to bleed their brakes... I want to order speed bleeders but i am just asking if you know the size of these bleeders (before I take out the wheels...) on a '05 3.0R spec. B. Is this M10 SB1010 (http://www.speedbleeder.zoovy.com/c=JX5hsn9TMT3Zh5Mu5o0UVrMJk/product/SB1010/SB1010-Speed-Bleeder.html) front and M7 SB7100 (http://www.speedbleeder.zoovy.com/c=JX5hsn9TMT3Zh5Mu5o0UVrMJk/product/SB7100/SB7100-Speed-Bleeder.html) rear ? Or SB1010 front and rear ? Link to comment Share on other sites More sharing options...
dan04103 Posted December 5, 2012 Share Posted December 5, 2012 I recommend using the motiv brake bleeder. I use it with great success. Link to comment Share on other sites More sharing options...
sheppo9 Posted December 5, 2012 Share Posted December 5, 2012 I used this quote from some shop; If an 8mm wrench fits on the front screws you will need (2) pairs of SB7100 bleeders. If a 10mm wrench fits on the front screws you will need (1) pair of the SB1010 and (1) pair of the SB7100 bleeders. I've used that for 3 different Subaru's and it's been right for them. Link to comment Share on other sites More sharing options...
asylum Posted December 6, 2012 Author Share Posted December 6, 2012 Thanks for the answer ! Link to comment Share on other sites More sharing options...
theflystyle Posted December 10, 2012 Share Posted December 10, 2012 i just bleed my brakes and IIRC that is what I ended up using. I recommend getting a set of pass through sockets so you can have some tubing going through the socket as you loosen. This makes the job much easier and cleaner. Link to comment Share on other sites More sharing options...
