subeysnow Posted October 21, 2007 Share Posted October 21, 2007 Does anyone here have any experience with JL's RBC? I had my installer put in a 500.1v2 amp with the RBC today.... and I can't for the life of me tell the difference of when it's turned all the way up or down. Is this due to a bad install, or does the RBC not really work. Link to comment Share on other sites More sharing options...
jvento Posted October 21, 2007 Share Posted October 21, 2007 It work for me what type of sub did u put in or it can be the rbc is bad. Link to comment Share on other sites More sharing options...
Magic Posted October 21, 2007 Share Posted October 21, 2007 Unplug the RBC from the amp and then mauanly turn up the gain on the amp. If that works you either have a bad RBC or a bad cable Click Here everyday:redface: Link to comment Share on other sites More sharing options...
FishingFiend Posted October 21, 2007 Share Posted October 21, 2007 The effects of turning the RBC should be obvious when connected and configured correctly. Time to troubleshoot or bring it back to your installer. It should be a relatively simple fix assuming your amp is reachable. Link to comment Share on other sites More sharing options...
subeysnow Posted October 21, 2007 Author Share Posted October 21, 2007 It work for me what type of sub did u put in or it can be the rbc is bad. put in a JL 10W6v2 Link to comment Share on other sites More sharing options...
subeysnow Posted October 22, 2007 Author Share Posted October 22, 2007 tried everything....gotta take it back to the installer. Link to comment Share on other sites More sharing options...
PGT Posted October 22, 2007 Share Posted October 22, 2007 yeah...I had the Stealthbox on a 500/1 and it was quite useful. Have them take a look. Keep in mind, it's not a volume control but bass boost level control (the bass boost ckt needs to be enabled). Link to comment Share on other sites More sharing options...
eb50 Posted October 26, 2007 Share Posted October 26, 2007 i had the same problem. bass boost MUST be enabled Link to comment Share on other sites More sharing options...
subeysnow Posted October 27, 2007 Author Share Posted October 27, 2007 here's my original set up on the amp: Output Mode: Full Range Filter Freq: 55 Filter Slope: 12db Filter Mode: LP Infrasonic Moniter: On Infrasonic Frequency: 50 "Q": 1.1 Center Frequency: 60 Boost: +10 Bass Eq: ON Amp LP Filter: OFF Filter Freq: 40 Amplifier Input Section Input Voltage: Low Signal Sensing: Off --------- I changed the Amp LP Filter from "off" to 12db and now the RBC works!! Thanks everyone. Any suggestions to dial in the amp? I'm running a 10w6v2. Link to comment Share on other sites More sharing options...
PGT Posted October 27, 2007 Share Posted October 27, 2007 check out JL's instructions for the Stealthbox for the LGT....they have recommended settings Link to comment Share on other sites More sharing options...
subeysnow Posted October 27, 2007 Author Share Posted October 27, 2007 Broken link on JL website. Anyone have instructions they can email me? Link to comment Share on other sites More sharing options...
newbwrx Posted October 27, 2007 Share Posted October 27, 2007 Try this:)SB_S_LWAG_10W6v2[1].pdf Link to comment Share on other sites More sharing options...
mlrtime Posted October 27, 2007 Share Posted October 27, 2007 Sorry for hijack but does the RBC work with a 250.1? Link to comment Share on other sites More sharing options...
msmith Posted October 29, 2007 Share Posted October 29, 2007 Sorry for hijack but does the RBC work with a 250.1? Only with the 250/1v2... the original 250/1 had no connection for the RBC-1. Link to comment Share on other sites More sharing options...
