ChefRacer Posted December 6, 2013 Share Posted December 6, 2013 So I just got my car back together after doing clutch/headers/single fuel line replacement and my fuel pressure won't go past approx 30 psi at idle. I have ID1000s with a sidefeed to topfeed conversion AEM adjustable FPR Walbro 255 and custom made by me fuel routings under the hood. I replaced the fuel line going from the passenger rail to the fpr b/c I had previously joined 2 hoses together to adapt down from the 3/8" fuel hose to the 5/16 stock fpr, and then back up to 3/8" when the stock fpr wasn't able to handle the rest of the setup. At the time I didn't have the time to take everything apart to run a single fuel line there, so I just joined 2 hoses of standard 160 psi fuel line. I just switched this to a 300 psi max fuel line without the connections in the middle of the hose. When I went to start the car, afrs were in the 16-17 range, I pulled a knock code and my fuel pressure wouldn't go above 30 psi with the regulator adjusted to the max. At this point, I disassembled the fpr, put a new diaphragm in it and changed out the nozzle inside for a smaller one to increase the pressure. Before I changed the hose out, my fuel pressure would drop off as soon as I turned the car off and it would turn over for a bit before starting. Now fuel pressure is holding constant, but I don't have enough of it. Any advice is appreciated. Thanks Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 6, 2013 Share Posted December 6, 2013 My guess is that the pump is bad. They generally just go and when they do, it simply goes down in fuel pressure or to none at all. Link to comment Share on other sites More sharing options...
ChefRacer Posted December 6, 2013 Author Share Posted December 6, 2013 I'm hoping for the same thing. Should be getting a pump right now Link to comment Share on other sites More sharing options...
ChefRacer Posted December 8, 2013 Author Share Posted December 8, 2013 So I replaced the Walbro 255 with a Deatchwerks 300 and I'm still getting the same issue. IDK what to do, I'm supposed to start a new job tomorrow and I can't get there. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 8, 2013 Share Posted December 8, 2013 http://legacygt.com/forums/showthrea...en-213570.html Take a look at this thread and see if it would help. Possibly your wiring to the pump itself is not good enough to spin it fast enough. Also, did you check the sock inside of the tank to make sure it wasn't plugged? Last, you can disconnect the fuel lines at both ends (pump and fuel rail) and blow some air lightly through it to make sure that it's not blocked in any way. Link to comment Share on other sites More sharing options...
