ece_tim Posted June 4, 2008 Share Posted June 4, 2008 So for you 05 guys out there, with higher mileage (say 50-60K+), are you seeing any common part failures? Obviously normal maintenance is key, but are there any non-maintenance repairs you're having to make? Anything to watch out for? I assume not, as my 97 LGT is going strong at almost 214K, but wanted to have some insight as I'm shopping. Thanks! Link to comment Share on other sites More sharing options...
BlackHole Posted June 4, 2008 Share Posted June 4, 2008 Wheel bearings, but they're practically a regular maintenance item on Subies. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
ece_tim Posted June 4, 2008 Author Share Posted June 4, 2008 Yeah that was a thought of mine as well. How much do those run parts & labor? Link to comment Share on other sites More sharing options...
westy66 Posted June 4, 2008 Share Posted June 4, 2008 i pull the hub off myself then take to machine shop. about $60 (with Subaru part) Link to comment Share on other sites More sharing options...
Scotty Posted June 4, 2008 Share Posted June 4, 2008 I'm at 104,8xx right now. No major repairs. Moonroof still broken. Rattle in the dash, e-brake, roof, extended armrest. Need to go in for timing belt next week. Link to comment Share on other sites More sharing options...
ece_tim Posted June 4, 2008 Author Share Posted June 4, 2008 Gah, STILL timing belts? I wonder how bad the book is on labor for that? Link to comment Share on other sites More sharing options...
mars_volta Posted June 4, 2008 Share Posted June 4, 2008 i have 66k on mine. had it a month. no problems yet and the cars service history was clean. Link to comment Share on other sites More sharing options...
Scotty Posted June 4, 2008 Share Posted June 4, 2008 I think they quoted me about $700 when I asked at 90K service. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted June 4, 2008 Share Posted June 4, 2008 Over 92k & the only thing that fails is the driving & low beam headlights. I go threw 2 to 3 set a year. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
slimjoe Posted June 4, 2008 Share Posted June 4, 2008 Just over 50k and nothing wrong. The TGVs were stuck closed about two weeks ago but resolved itself after a few hours when I left work early (to poke at it). Other than that, a few CEL's for the TGVs (happened three times last year but no real issue) and that's about it. Oh.. and the low beams burning out are a pain but it's a quick and simple replacement for the H7's. Link to comment Share on other sites More sharing options...
AirSix Posted June 4, 2008 Share Posted June 4, 2008 60K on the clock and had to replace rear wheel bearings at about 40K and AF sensor at about 50K. I did new rotors, pads, stainless lines at 40K so I could take it to some track days. Currently the damn thing is suffering from lower than usual boost levels, which has me befuddled. I had the 60K done and nothing's changed. I need to get my hands on a laptop so I can data log. (begin anti-jinx) Other than that she's been problem free (end anti-jinx) I tell myself that an N/A Forester is just an STI without all the fluff like, power, handling, style, racing heritage, and curb appeal. Link to comment Share on other sites More sharing options...
whobaru Posted June 4, 2008 Share Posted June 4, 2008 Over 90k & the only thing that fails is the driving & low beam headlights. I go through 2 to 3 set a year. MikeMay I suggest a DRL disable and a set of these? Link to comment Share on other sites More sharing options...
franklin Posted June 4, 2008 Share Posted June 4, 2008 8 low beam headlight bulbs before i got smart and went with Zenon bulbs. Link to comment Share on other sites More sharing options...
SneakyFast Posted June 4, 2008 Share Posted June 4, 2008 50k miles. Not a single problem. Link to comment Share on other sites More sharing options...
hutru01 Posted June 4, 2008 Share Posted June 4, 2008 almost 60K miles here. Other than a upgrade to the IPT transmission (which was absolutely necessary with my turbo setup), the car has ran fine since I bought it in December with 54K miles Link to comment Share on other sites More sharing options...
Paul G. Posted June 4, 2008 Share Posted June 4, 2008 93K on my car. Headlight low-beam bulbs--I keep an H7 in my rear cubby. I can change them myself in a couple of minutes, even in the dark. Rear wheel bearing--one, but it is a design flaw. I had sticking front pads, called for replacement of rotors at 30K. Subie worked with me and I'm ok with it. Windshield--OEM is thin and fragile. After 2 from the dealer, I went aftermarket and have had no problems since. All-in-all, not unhappy, but I'm not a kool-aid kinda guy. Still love my car. P. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted June 4, 2008 Share Posted June 4, 2008 What noise do the wheel bearings make when they start to fail? Shriek? Link to comment Share on other sites More sharing options...
ncretter Posted June 4, 2008 Share Posted June 4, 2008 +1 to the TGV Dashboard rattle some squeak, maybe the springs in the back (should I look at replacing those? How do I know when my shocks or springs need replacing) Link to comment Share on other sites More sharing options...
bradlgt21 Posted June 4, 2008 Share Posted June 4, 2008 The wheel bearings are warrantied for like 8 years or something now because of the problems. Got a letter in the mail from SOA a while ago about it. Link to comment Share on other sites More sharing options...
AirSix Posted June 5, 2008 Share Posted June 5, 2008 The wheel bearings are warrantied for like 8 years or something now because of the problems. Got a letter in the mail from SOA a while ago about it. Should be the same for the friggin H7 bulbs. Some idiot engineer in the Headlamp Department is costing me at minimum 2 bulbs a year since I drove it off the lot. I tell myself that an N/A Forester is just an STI without all the fluff like, power, handling, style, racing heritage, and curb appeal. Link to comment Share on other sites More sharing options...
goneskiian Posted June 5, 2008 Share Posted June 5, 2008 Wheel bearings have an extended warranty for 8 years/100K now. At least for the '05's and '06's. Some of you definitely need to do the DRL disable. I've only replaced 2 headlights (one on each side) since driving it off the lot. Watch, both will go out in the next couple of days! :lol: OP - Check the Warranty Issues and Problems discussions for more info on things going wrong. Cheers! Link to comment Share on other sites More sharing options...
UniqueTII Posted June 5, 2008 Share Posted June 5, 2008 I'm over 70K with stage 3.14 and the only issue is a whine in the tranny. Link to comment Share on other sites More sharing options...
Cynder Posted June 5, 2008 Share Posted June 5, 2008 I'm at 47K and the only service issue I've had was to replace a faulty fuel injector over the winter, covered under warranty. Maintenance shows I've got 50% or more brake pad, little or no wear on the rotors and I've only needed to replace one H7. No performance mods other than a K&N direct replacement airfilter. As the car ages, it's getting a few extra squeeks. I love this car, seriously. Link to comment Share on other sites More sharing options...
Scruit Posted June 5, 2008 Share Posted June 5, 2008 40k. Replaced one headlight bulb. Nothing else needed. No drivetrain mods except K&N panel filter. Link to comment Share on other sites More sharing options...
kingdomGT Posted June 5, 2008 Share Posted June 5, 2008 Just a few miles from 50K, bought her new in Feb. of '05. Replaced lamps once (thank goodness, sounds like a regimen for some...) Surfaced rotors once - SS lines and HPS pads are on the list soon Replaced Radio (Warranty) Otherwise, some rattles that really only occur when temperatures are lower (<60F or so, heats up and everything seems to fit together nicely) and sometimes getting into reverse is a pain (shift into first, then to reverse and syncros don't always line up. let out the clutch, try again and it works) Only mods have happened within the last month: Rallitek Sways F/R, AVO Panel Filter The car is a dream and I'm excited every day to drive her! Link to comment Share on other sites More sharing options...
