Calypsooofast Posted September 15, 2013 Share Posted September 15, 2013 hey guys i dont post here much but i do read a lot...have had success w problems in the past on here so if you guys could help me out would be great... Problem: recently my 07 LGT w 134k has been running hott. When driving (weather on highway doing 80mph in 50deg weather or driving around town in 75deg heat) it has been slowly creeping and holding steady around the 3/4 mark...ive owned my car since new and i know this isnt normal it religiously used to sit just a tick below the middle...ive flushed the system, changed the t-stat and still persists. havent changed the rad cap yet and no leak that i can see under the car...it will never enter the red area of the temp guage either even if i let it idle. actually sometimes it comes down back to normal for a few mins then creeps back up...:confused:any ideas where to start... thanks in advance Link to comment Share on other sites More sharing options...
rob-2 Posted September 15, 2013 Share Posted September 15, 2013 How is the coolant level? When you inspect is the system full? Link to comment Share on other sites More sharing options...
Calypsooofast Posted September 15, 2013 Author Share Posted September 15, 2013 i checked the rad coolant level and it was full...the overflow was pretty good too...:confused: Link to comment Share on other sites More sharing options...
yardie Posted September 15, 2013 Share Posted September 15, 2013 Did you burp the system after refilling? Check the rad and a/c fans if they are working. Link to comment Share on other sites More sharing options...
HarryD Posted September 15, 2013 Share Posted September 15, 2013 Regarding the thermostat, was it replaced with an OEM one from Subaru? There have been a number of circumstances reported of replacing with aftermarket thermostats and having problems. Link to comment Share on other sites More sharing options...
rob-2 Posted September 15, 2013 Share Posted September 15, 2013 Did you check the turbo resi? That's the high point and needs fluid. It can be low and the overflow full. Link to comment Share on other sites More sharing options...
Calypsooofast Posted September 15, 2013 Author Share Posted September 15, 2013 i brought it to my mechanic...he flushed the system and did the tstat...i assume he burped the system hes pretty efficient and thurough with that stuff...i did not check the turbo resi....where can i access that and wheat level should it be at if the car is cold... also...idk if it matters but when i shut the car off i get that sound of water flowing/gushing from the driverside dashboard area...that related? Link to comment Share on other sites More sharing options...
Calypsooofast Posted September 15, 2013 Author Share Posted September 15, 2013 ...cont....just checked the turbo res...its full....the fans are def working and im not 100% sure if he used a oem thermostat...ill have to ask....any other ideas? Link to comment Share on other sites More sharing options...
wawazat Posted September 15, 2013 Share Posted September 15, 2013 Have you cleaned the front of the radiator? I ask as I just had my radiator replaced and the front face of the stock radiator was pretty well covered with a variety of stuff. My car has 110k miles on it. I replaced the radiator while doing the 105k service as a precaution. Link to comment Share on other sites More sharing options...
Calypsooofast Posted September 15, 2013 Author Share Posted September 15, 2013 ^good point ill check... anyone know what that sound of swishing water is about from the dash??? Link to comment Share on other sites More sharing options...
Cobshane Posted September 15, 2013 Share Posted September 15, 2013 That's an indicator of air in the system or heater core. May want to try burping the system again. The rushing water sound is coolant flowing through an air pocket. This may be caused by air left in the system or a head gasket starting to fail and it is pumping combustion in the cooling system and creating an air pocket. Link to comment Share on other sites More sharing options...
Calypsooofast Posted September 15, 2013 Author Share Posted September 15, 2013 That's an indicator of air in the system or heater core. May want to try burping the system again. The rushing water sound is coolant flowing through an air pocket. This may be caused by air left in the system or a head gasket starting to fail and it is pumping combustion in the cooling system and creating an air pocket. sickkkkkkk...ugh was hoping it wasn't the head gasket....ill try burping the system...whatsthe best way just to run the car up to temp with the rad cap off and squeeze the upper hose a few times to get the air out? Link to comment Share on other sites More sharing options...
JJr Posted September 15, 2013 Share Posted September 15, 2013 I'd bet it's air in the system not a HG! Try this. http://legacygt.com/forums/showthread.php/coolant-system-bleeding-99457.html Link to comment Share on other sites More sharing options...
Cobshane Posted September 15, 2013 Share Posted September 15, 2013 As described in the link undo cap at turbo res. and run till its nice and warm (running temp. for about 10 or so minutes) and run your heater at full blast hot. Make sure pumping out really hot air out the vents. If its blowing Luke warm then air is still there so keep running it. Link to comment Share on other sites More sharing options...
Calypsooofast Posted September 17, 2013 Author Share Posted September 17, 2013 As described in the link undo cap at turbo res. and run till its nice and warm (running temp. for about 10 or so minutes) and run your heater at full blast hot. Make sure pumping out really hot air out the vents. If its blowing Luke warm then air is still there so keep running it. ok thanks for the breakdown...im gonna try this tomorrow morning....will the system force the air out itself as it runs/warms up or should I squeeze the upper rad hose a buncha times to force air through the system? Link to comment Share on other sites More sharing options...
Cobshane Posted September 17, 2013 Share Posted September 17, 2013 It couldn't hurt, but you might have some coolant slosh out as you might even if you don't squeeze it. So have some coolant handy to top the system off. Link to comment Share on other sites More sharing options...
LatentWagen Posted September 19, 2013 Share Posted September 19, 2013 Did you figure it out yet? I'd think that at 134K you'll want to do the radiator as preventative maintenance anyway. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
