cypher0117 Posted May 2, 2012 Share Posted May 2, 2012 After searching for a tmic, I have come across hundreds of threads talking about quality/fitment/core design but I have not been able to find any document test between any intercooler (flow, temperature change, boost level, etc ). I've come to the conclusion that the process west tmic is the best option for staying top mount, but also quite costly. Has anyone done any flow/pressure/temperature tests on any aftermarket and stock intercoolers to actually determine if these knockoffs are worth the quality differences? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 2, 2012 Share Posted May 2, 2012 All that only matters if your looking to the max amount of HP you can make. For a strong DD it really doesn't matter. For 95% of us it's all about the cost. If your that worried about all that flow and stuff you better be looking at a fmic or may be air/water. Let it go and just get what you can afford. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RedDawg Posted May 2, 2012 Share Posted May 2, 2012 so you yourself haven't done any testing, but you've concluded that the process west tmic is the best one? Link to comment Share on other sites More sharing options...
cypher0117 Posted May 2, 2012 Author Share Posted May 2, 2012 I've concluded that only based on what I've read on this forum, which is only based on fitment/quality of build. I honestly have no idea which one is best which is why I posed the question Link to comment Share on other sites More sharing options...
robitrice Posted May 2, 2012 Share Posted May 2, 2012 best is vague and personal. Get what you can afford and what works for your goals. Process West is great but its expensive. Other have used the FMS and have had success and others have not. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 2, 2012 Share Posted May 2, 2012 There was a thread here a few weeks ago about which is better But it turned into buy what you can afford for a DD. The Perrin is better than the IRP but it's also more money. How much more HP you you get from it. Is it worth it for you. Worry more about fitment. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Heedz Posted May 6, 2012 Share Posted May 6, 2012 WPMarky is running the processwest knock off, holding boost fine, the metal quality definitely is not par with the PW one but, what's the difference if performance is the same, unless names and brands matter to you. obviously the nicer one definitely gives your engine a better look. Link to comment Share on other sites More sharing options...
m sprank Posted May 6, 2012 Share Posted May 6, 2012 Performance from the knock off TMIC's is not the same as performance from the originals. It is just better than stock. We have seen issues from mis-fits, to mis-tapped threads, to metal shavings in the end tanks (left over from the cores being cut). Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted May 6, 2012 Share Posted May 6, 2012 We have seen issues from mis-fits, to mis-tapped threads, to metal shavings in the end tanks (left over from the cores being cut). Thats just f'd up. Link to comment Share on other sites More sharing options...
