bihsoccer14 Posted November 2, 2011 Share Posted November 2, 2011 i just bought a 04 sti turbo, sti top mount, sti intake mainifold. turbo inlet and have a avo intake i am just waiting to put it all in . i am getting a road tune i was just wondering what kind of power i am looking to be looking at its 05 legacy gt 5eat Link to comment Share on other sites More sharing options...
bmx045 Posted November 2, 2011 Share Posted November 2, 2011 You will be fast like an sti. Link to comment Share on other sites More sharing options...
Code Posted November 2, 2011 Share Posted November 2, 2011 Stock fueling? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
robitrice Posted November 2, 2011 Share Posted November 2, 2011 any other mods? IE: Dp, Up pipe? without those i would not picture u making a great improvement compared to if you did. Dont go crazy on mods with the 5EAT, you will need to beef that up even at the Stage 2 power levels with the valve body mod, tranny cooler etc. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 3, 2011 Share Posted November 3, 2011 You will be fast like an sti. Oh like Cobb AP at Stage1. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
mustangendsley Posted November 3, 2011 Share Posted November 3, 2011 I really dont understand this swap method. Are cars are closed to a STI. Why do all the changes? and i dont think there are that many diff turbos out there that are going to be that diff with this set up. Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted November 3, 2011 Mega Users Share Posted November 3, 2011 ^Nice input! Link to comment Share on other sites More sharing options...
bihsoccer14 Posted November 4, 2011 Author Share Posted November 4, 2011 I got the turbo and intercooler for 120 bucks and had to but the sti manifold. Cheap easy way to get some power I guess I am thinking of getting a upipe and a downpipe as well before I get the tune . I was wondering what the transmission mod was Link to comment Share on other sites More sharing options...
GTO5005 Posted November 4, 2011 Share Posted November 4, 2011 That transmission mod is the F1 Valve Body Mod by Hexmods, so far I believe its just for the 05-07 5EATs , and they are working on a VB mod for the 08+. I have read nothing but good things about the mod so far, and the difference in shifting is supposed to be pretty noticeable. Apparently you can run up to 350+ whp with it, however if your going to launch (brake boost) your car you need to get some bushings that they also sell for 200ish. I myself am stuck between this mod and a cbe for my next mod. Here is a link with all the details about the mod: Link to comment Share on other sites More sharing options...
GTO5005 Posted November 4, 2011 Share Posted November 4, 2011 http://legacygt.com/forums/showthread.php/5eat-valve-body-upgrades-finally-164484.html?t=164484&highlight=climberD Link to comment Share on other sites More sharing options...
Infamous1 Posted November 4, 2011 Share Posted November 4, 2011 I hate STi swaps...I always recommend to go front mount...more power, less headache. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2011 Share Posted November 4, 2011 I got the turbo and intercooler for 120 bucks    Good luck with that. Are you sure the turbo is good ? When these turbo's blow it normally put's metal chips into the oil pan and takes out the short block. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
compsurge Posted November 4, 2011 Share Posted November 4, 2011 OP: if the turbo is bad, you can get it rebuilt by BNR as a hybrid turbo. You are limiting yourself using stock fuel (injectors and pump). Link to comment Share on other sites More sharing options...
whitetiger Posted November 4, 2011 Share Posted November 4, 2011 I hate STi swaps...I always recommend to go front mount...more power, less headache.  agreed. the STI swap was what the LGT community used to have to do due to the lack of aftermarket ICs and bolt on turbos that fit the LGT's newer style TMIC setup. now since the 08 wrx has come out, ther are alot more aftermarket options that don't require a IM swap to fit. Id say the era of the STI IM swap is dead. Link to comment Share on other sites More sharing options...
mumblinaviator Posted November 4, 2011 Share Posted November 4, 2011 Me thinks he's discovered the rabbit hole that is stage 3.... Need other stage 2 supprting mods before you can expect any return on your stage 3 investments. Then beef up the fueling and you're set. Link to comment Share on other sites More sharing options...
bmx045 Posted November 4, 2011 Share Posted November 4, 2011 the composite manifold performs better than the aluminum type, less heat soak. an sti swap is a waste of time IMO. Link to comment Share on other sites More sharing options...
rweezy Posted November 4, 2011 Share Posted November 4, 2011 Man so much hate for the sti swap. I have it but didnt install it that way. Ive driven leggys with far better set ups and will say its not a huge difference. Most definetly noticable but not that much more. 120 bucks is a good deal assuming the turbo is good. Since your a 5eat the sti set up might be a good way to go so you dont go crazy with power and roast the tranny. Like others have said with out other supporting mods though your gains will be on the lower side of things. Link to comment Share on other sites More sharing options...
bihsoccer14 Posted November 5, 2011 Author Share Posted November 5, 2011 i got it from a close friend he just put 8000 in his sti , my goal is 400 to 450 hp if that i just want it to be faster and have fun with the car Link to comment Share on other sites More sharing options...
grantLGT Posted November 5, 2011 Share Posted November 5, 2011 i got it from a close friend he just put 8000 in his sti , my goal is 400 to 450 hp if that i just want it to be faster and have fun with the car With that much power you will need the hexmod valve body or your tranny WILL die. im doing that modd before any other power modds. Link to comment Share on other sites More sharing options...
bihsoccer14 Posted November 6, 2011 Author Share Posted November 6, 2011 Do you have to drop your transmission out ? And how much does the Gilbert body cost Link to comment Share on other sites More sharing options...
Code Posted November 6, 2011 Share Posted November 6, 2011 Are you expecting that power from the Sti swap? Cuz it ain't gonna happen even on corn/meth/race gas. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
bmx045 Posted November 6, 2011 Share Posted November 6, 2011 Do you have to drop your transmission out ? And how much does the Gilbert body cost Autocorrect ftw. The hexmods valve body mod is in the vendor classifieds forum. Link to comment Share on other sites More sharing options...
bihsoccer14 Posted November 6, 2011 Author Share Posted November 6, 2011 Thanks. And no I don't think I will get that power from the sti swap if I do get a front mount I can still be the legacy gt kit right Link to comment Share on other sites More sharing options...
bmx045 Posted November 7, 2011 Share Posted November 7, 2011 no, the intake manifold for the sti is much different than the legacy. You'd need to rig up your own pipe in order to reach the throttle body in the center of the mani. Link to comment Share on other sites More sharing options...
bihsoccer14 Posted November 7, 2011 Author Share Posted November 7, 2011 okay thank you so i am about to start putting in the stuff in the car this week anything i should know about any warnings ? sorry for all the questions i just want to do it right you can call me a noob Link to comment Share on other sites More sharing options...
