Heads Up--Cobb Sway Bar Mounting Failure
Deepwoods
The metal tab which connects the bar to the chassis failed, ripping off the frame.
I noticed a klinking sound coming from the rear driver-side wheel well. When put on a lift, I was shown that the left side of the bar was completely unattached...
I guess the mount could not handle the increased strength/ stiffness of the sway bar. Anyway, just a heads up for those with Cobb, and other aftermarket sway bars.
Currently, I sit in the showroom of a fabrication shop, awaiting my new and improved bar mounts.
There are 2 mounting points:
Endlink (doesn't sound like you are talking about that)
Sway Bar Bushing Mounts
On the Cobb Rear Sway, you've got 2 bolts going through the sway bar bushing strap, cobb reinforcement plate, stock mounting plate, and (at the bottom) the Cobb reinforcement bracket.
What exactly broke in there? It's a helluva lot stronger setup than stock....and running anything short of at least an extreme performance summer tire.....well, I can't see generating enough torsional force to sheer a bolt or break the mounting plate.
Joe
Edit: I re-read this to be saying that the top of the stock mounting plate ripped off the frame. Is this accurate?
Rear sway bars should have come with reinforced bar mounts.
http://cobbtuning.com/products/?id=2451
A reminder for those folks that don't know. The weakness of the rear sway bar mounting point is a known problem. There are a few companies that make a reinforced mounting bracket to resolve that problem.
If you are planning on installing a rear sway bar please be sure you are aware of the above problem. If you don't have one your rear sway bar mount may look like above.
Whitetiger - I looked them up. The AVO ones at least look weaker than the Cobb setup.....Cobb reinforces the metal with a new plate and then provides a direct reinforcement through an external bracket bolted through the most leveraged part of the mounting bracket....the bottom. The bottom is then connected to a rear-diff mounting bolt.
To me, it's the best way to reinforce the stock bracket....and how it should've come stock. Leaving a major suspension mount extending 4" perpendicular to the frame is just screaming to be bent. Reinforcing it is definitely a first step, but it needs an external angled support (such as the Cobb) to really help distribute the forces exerted in the end of it...
Just my .02
Joe
I'll see if I can get pictures of the reinforcements, but the new ones much thicker, and have a couple points of bracing. The car's stiffness in the turns has returned.
Thanks to the folks at Piper Motorsports in Sterling, VA. They fit me in the schedule at short notice and had me out in 2.5 hours. (They are also, working on a v10 engined E30 M3, which is pretty cool...)
Holy F....that's gotta be a small displacement V10. The E30 engine bay was NOT big....maybe a 4.0 liter V10?
Anyway....awesome that they got you out quickly. What did it run you price wise?
Whitetiger- You are probably right about the AVO reinforcement. I didn't think anythign special of the Cobb until I held it in my hand, then I realized how much it would add.
Joe
