zepplinluvr2 Posted February 20, 2013 Share Posted February 20, 2013 So I've noticed that my clutch has been acting weird. It releases lower, and then sometimes it releases all the way at the top. I also hear a noise when I first start the car. Throw out bearing? What do you guys think it is? I don't think it's the clutch pad itself because it still grabs hard. I checked the hydraulic fluid on the slave cylinder and it is full. Any suggestions before I install a new clutch and find out that it's not the clutch? haha. I don't want that to be the case, but what happens when the throw out bearing goes out? Signs and symptoms? Any help is appreciated. I have a 2005 LGT Limited Wagon. HELP!! :confused: Link to comment Share on other sites More sharing options...
wurkenman Posted February 20, 2013 Share Posted February 20, 2013 Maybe snout wear on the mainshaft of the trans. Search this. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
zepplinluvr2 Posted February 20, 2013 Author Share Posted February 20, 2013 That stuff is very confusing for me. I did some research and still don't know. What are the symptoms of a bad throw out bearing on these cars? That noise it makes when it's cold, when I start it, makes me think that that is it. Link to comment Share on other sites More sharing options...
rob-2 Posted February 20, 2013 Share Posted February 20, 2013 If it's not too much trouble I'd bleed the system before I tore it part for a new clutch, unless with mileage you're pretty certain you're going to need replacing. Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2013 Share Posted February 20, 2013 My vote goes to TOB. Better check before something explodes and wrecks your snout. Link to comment Share on other sites More sharing options...
