~~~Plug and Play HID Install Walkthrough~~~
Below is a link to the only HID install walkthrough I could find, so I figured we need one of our own. Note: I am in no way responsible for anything having to do with this walkthrough.
http://pimpmyauto.com/Legacys/H7%20HID%20kit%20install.htm
Use that link to disable your DRLs ('05-'06), on '07 you must "cut the blue/black wire" instead of unplugging them (otherwise highbeams and fogs won't work). Apparently the '08s may not need the DRLs disabled because it is the high beams that are the DRLs (at a lower output). If you unplug the DRLs like on an '05 or '06, it will disable them, but your high beam indicator will no longer work. If your okay with no high beam indicator, apparently you can just unplug them and be done. Cutting the blue/black wire has worked for some members on their '08s. Here's a link to the discussion for the '08s: http://legacygt.com/forums/showthread.php?t=75320. Apparently the '08s use the high beams on a low setting for the DRLs though, so no disable should be necessary. Once you've got the DRLs disabled ('05-'07), use this walkthrough for the HIDs.
This walkthrough is for a plug and play kit like the Apexcone I've used.
First, remove the factory light bulb. The plastic cap comes off counter clockwise if you're looking at the back of the headlight. It's labeled. The retainer spring is easy to undo.
http://i180.photobucket.com/albums/x312/kagenmateer/removefactorybulb.jpg
This is what you're left with. Circled in red is the factory grommet if you want to use it to run your wires. Good luck with that.
http://i180.photobucket.com/albums/x312/kagenmateer/whatyourleftwith.jpg
You'll need to break off the black plastic thingys. They're just for shipping.
http://i180.photobucket.com/albums/x312/kagenmateer/break.jpg
This pic is self explanatory. As labeled, that's a 1" drill bit.
http://i180.photobucket.com/albums/x312/kagenmateer/1inchhole.jpg
You'll need to notch out the 1" hole on each side for this connector to make it through. I used a dremel.
http://i180.photobucket.com/albums/x312/kagenmateer/makeroom.jpg
This is what it looks like with the wires through the plastic bulb cap and the weather seal grommet in place. You can't really see the grommet in this pic.
http://i180.photobucket.com/albums/x312/kagenmateer/wiresthrough.jpg
Time to put the bulb in. After a couple tries, I found this to be the best grip to install the HID bulb. I grabbed the bulb base with one hand and let everything else hang. Not that it's real complicated or anything.
http://i180.photobucket.com/albums/x312/kagenmateer/gripforinsert.jpg
This is with the HID bulb in place and both spades connected. The red wire goes to factory pink, and black goes to black. What looks like it used to be a black wire on the factory plug is washed out by a white powder, making it look greyish. This is probably powderized rubber from the wire jacket being exposed to the heat. Note: apparently some kits have black and blue wires, so put blue to suby pink and black still goes to black.
http://i180.photobucket.com/albums/x312/kagenmateer/bulbinplacewiresconnected.jpg
Now that everything is connected, you might as well try it out to make sure everything's going right!
http://i180.photobucket.com/albums/x312/kagenmateer/tryitout.jpg
After you've confirmed it works, tape each wire individually so there's no chance they can touch.
http://i180.photobucket.com/albums/x312/kagenmateer/tapeeach.jpg
  • Replies 425
  • Created
  • Last Reply
Then tape both wires together to protect them. Use plenty, tape is cheap!
http://i180.photobucket.com/albums/x312/kagenmateer/tapeboth.jpg
Now, re-install the plastic cap. Looks nice, huh?
http://i180.photobucket.com/albums/x312/kagenmateer/reinstallcap.jpg
It was quite convenient to mount the ballast to my AEM CAI heat shield.
http://i180.photobucket.com/albums/x312/kagenmateer/ballastlocation.jpg
After the sticky failed, I fabricated this bracket to hold the ballast on better
http://i180.photobucket.com/albums/x312/kagenmateer/bracket.jpg
I was able to tuck my wires behind the AEM heat shield. Always get your wires neatly out of the way.
http://i180.photobucket.com/albums/x312/kagenmateer/tuckwires.jpg
This is where I ended up putting the driver ballast. The driver side is definitely a much tighter space than the passenger, so do the passenger side first!
http://i180.photobucket.com/albums/x312/kagenmateer/driverballast.jpg
After the sticky failed on this side, this is how I secured it. Two 9" zip-ties connected to make a really long one...going all the way around the frame
http://i180.photobucket.com/albums/x312/kagenmateer/IMG_3138.jpg
Here's my LGT with the HIDs vs. my Mazda 6 with factory halogens.
http://i180.photobucket.com/albums/x312/kagenmateer/LGTvs6.jpg
Here's a couple straight on pics.
http://i180.photobucket.com/albums/x312/kagenmateer/straightondark.jpg
http://i180.photobucket.com/albums/x312/kagenmateer/straightonlit.jpg
Here's a side view. This is with blacked out lights and Sylvania Silverstar bulbs
http://i180.photobucket.com/albums/x312/kagenmateer/sideview.jpg
Enjoy!!
Update: See posts 167, 170 and 180 for some other information and ideas.
Also, the dust caps can be purchased from your local dealer for around $20 shipped if you're worried about drilling them. The part number is 84953AG060.
Nice walkthrough - I wish you'd written this about a week ago! :lol: I followed scans' directions, drilled a too-small hole in the plastic cover, and had to spend some quality time with my dremel to get that connector through...
sorry...this forum practically blows goat nuts so im not always on here.
Team Pony Express
POSTED FROM MY COMPUTER USING A WEB BROWSER
You can also do this without drilling the caps. Looking at the Apexcone Kit, I don't know if it is possible, but I know the older kits (Xtec...before Apexcone bought them) could do it. I was looking for the walkthrough I followed, but I couldn't find it.
Basically, what you have to do is open up that black plug where the red and black wires are, and push out the stock grommet and route those wires outside of the housing. After doing that, you can route the HID grommet through the stock spot.
It's not completely "plug and play" and you have have to mess with sliding the rubber around the wires down if the HID grommet doesn't have the length to get to the stock spot....but it is drill free. (I didn't have a drill, which is the reason I did it)
I did it without drilling the caps on my 07'. Just fished the wires through the grommets on the headlights. More work, but neater look. You can't even tell I have HID's.
I place the driver's side ballast on top on the windshield fluid reservoir, and the passenger under the headlight housing.
No problems whatsoever.
X
so if you guys are just doing plug and play ( no retrofit) how is the light quality? like is it way better than stock? are you constantly blinding people? I want to go hid but dont want to take my lights all apart to retrofit them.
The light is pretty good - a lot of that, of course, depends on the bulbs you choose, as 4500-5000k will give better light than 6000k or higher. I think the light is great with my 4500k kit. As far as blinding people, the light is still constrained by the cutoff in the stock projectors, although I believe the exact placement of the light source within the bulb may be off by a little bit. I haven't been flashed by anybody. Adjusting the aim on the headlights is key....
I'd say the plug-and-play kit was worth my $130, but I also understand those who go the retro route because they want perfection.
Team Pony Express
...looks mega bright! Just a couple of things make sure the ballast never touches the AEM and if you used double sided tape to stick on the ballast it may come off cause of the engine bays heat. Both scenarios I have been through!!! ;)
CRAZY KEN
CRAZY KEN
Good point. The driver side came unstuck, so I zip tied it. So far, so good on the passenger side.
Hey Bosco, you'd be an expert here... Hopefully this isn't a re-post, but I have an off-topic question. My APV2 showed up today. How will the 91 Octane Stage I map cooperate with my AEM CAI? Think I'll be dangerously lean or should I not worry about a custom tune 'til stage II? I have the AEM and a CBE (last cat removed).
i am far from an expert but i really don't think just a cai and cbe would change it enough to harm the engine at Stage 1. i would check with rao, fweasel or edmundu for more info to be double sure. once you do get to Stage 2 i would recommend a Pro Tune the difference in wtq and drivability was worth the trouble. bosco
Stay Stock Stay Happy
thx
