82DMC12 Posted June 3, 2014 Share Posted June 3, 2014 Hi guys, I recently had a ton of work done on my 2.5i. Now I see that when the engine is hot and the car is at idle, if the compressor kicks in the slows to almost a stall (doesn't stumble but very slow idle) for a couple seconds until it speeds up a bit and compressor shuts off. The air is cold and compressor is cycling normally. I had the head gaskets replaced because of the dreaded oil leak (Subaru paid half) so of course the belts were replaced, possibly the compressor was removed too, not sure. The belt deflection seems to be OK, maybe a bit on the tight side. Any ideas? Not the end of the world but it wasn't such a noticeable thing before. Link to comment Share on other sites More sharing options...
apexi Posted June 3, 2014 Share Posted June 3, 2014 I'm thinking they probably disconnected the battery, and the car is still relearning. Even if everyday driving is fine, I'm thinking if the compressor hasn't come on at idle much yet then the car hasn't has a chance to adjust to that. Link to comment Share on other sites More sharing options...
82DMC12 Posted June 3, 2014 Author Share Posted June 3, 2014 I actually replaced the battery a day before I realized this was happening. You think a loss of power would cause the ECU to relearn this? Didn't consider that. Sent from my DROID RAZR HD using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted June 3, 2014 Share Posted June 3, 2014 Yup, that's my guess. Non-turbo legacies act funny after the ecu has been reset. If the problem persists 3-4 weeks from now, then I'd start to think something might be wrong. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted June 5, 2014 Share Posted June 5, 2014 Hey 82DMC12, what mileage is your 2.5i? FWIW, mine dips in revs when the compressor engages too, more than I would've thought but I'm not too bothered. Link to comment Share on other sites More sharing options...
82DMC12 Posted June 5, 2014 Author Share Posted June 5, 2014 Its a 2008 2.5 ltd with 69k on it. Sent from my DROID RAZR HD using Tapatalk Link to comment Share on other sites More sharing options...
K2e2vin Posted June 5, 2014 Share Posted June 5, 2014 If they removed the compressor...maybe they slightly overfilled the system? Link to comment Share on other sites More sharing options...
