compression test
Energyblue98
  • Moderators
150 on all four would be great (honestly I wouldn't expect that--more likely to see 125-145). You should worry if you find a large difference between 1 or more cylinders. If they are all within 1-3psi that's a good thing.
Good results: 133/135/133/134
Bad results: 145/144/145/80
Not currently in stock :(
Also at what elevation you are located - 120 psi measured say in Albuquerque, NM at 6000 feet above sea level would translate to about 144 psi at sea level (which is what the values in the manual are quoted at)
Here's a table to correct (divide the pressure you measure at altitude by the correction factor to get the equivalent at sea level)
Altitude Factor
1000 .9711
2000 .9428
3000 .9151
4000 .8881
5000 .8617
6000 .8359
7000 .8106
8000 .7860
Anyway - as already pointed out, consistency is key - if you only see a couple psi variation cylinder to cylinder, you are probably fine (within reason - if they are all the same, and say 80psi or less, you might have a problem)
