Purple Jrank Posted April 16, 2012 Share Posted April 16, 2012 I have a 2005 Legacy with the standard radio that everyone wants to replace with a double din head unit. I am wondering whether it is possible to hook up something to control the HVAC settings without having the controls plugged in. Or if anyone in the Albany area has a radio lying around that I could hookup for 30 seconds to turn down the heat, that would also solve my problem. Soo... being the genius I am, I jumped right into doing the custom install that LLBean was kind to provide a detailed walk through for (http://legacygt.com/forums/showthread.php/finally-can-now-install-aftermarket-stereo-136272.html). However, because I have had almost no time to work on it since I removed and disassembled the radio, which I did when it was 0 degrees outside, it still is in the process of being soldered back together. What I did not realize is that the last setting for the HVAC controls is the one that it remembers, which happened to be be the full heat setting. That is why I am driving around in 80 degree weather with the heat blasting. It makes drives of more than 5 minutes fairly uncomfortable. Link to comment Share on other sites More sharing options...
zmarko Posted April 16, 2012 Share Posted April 16, 2012 Disconnect the battery for a while. It'll revert back to 75 degrees. Link to comment Share on other sites More sharing options...
Purple Jrank Posted April 16, 2012 Author Share Posted April 16, 2012 How long should I disconnect it for? Link to comment Share on other sites More sharing options...
zmarko Posted April 16, 2012 Share Posted April 16, 2012 How long should I disconnect it for? 10 mins will be fine. Probably can do it even less, but I know 10 mins will do it. Link to comment Share on other sites More sharing options...
Purple Jrank Posted April 17, 2012 Author Share Posted April 17, 2012 Thanks a lot!! I have been driving in some hot weather with the heat at full blast, so it was a pleasant experience to go for a long ride without adding to the misery. It is funny how I had been imagining that the solution would be complicated, but it was so simple in reality. I kind of feel stupid for not thinking of resetting the computers. Thanks again for the help! Link to comment Share on other sites More sharing options...
zmarko Posted April 17, 2012 Share Posted April 17, 2012 Thanks a lot!! I have been driving in some hot weather with the heat at full blast, so it was a pleasant experience to go for a long ride without adding to the misery. It is funny how I had been imagining that the solution would be complicated, but it was so simple in reality. I kind of feel stupid for not thinking of resetting the computers. Thanks again for the help! Not a problem. Glad it worked......I had disconnected the battery so many times and hated the HVAC resetting to 75 each time....but now I don't regret it. lol. Link to comment Share on other sites More sharing options...
