torinalth Posted October 28, 2011 Share Posted October 28, 2011 so, found this on my floor, apparently came out when I pulled the axle... where exactly do I put her back. on the other side, it seems to be just sitting inside the seal to the tranny, but does not look like it even serves a purpose as its not really "there" just sitting in the open area. thoughts? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 29, 2011 Share Posted October 29, 2011 The spring helps the seal stay around the axle. See if you can get it back inside the axle seal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Heedz Posted June 11, 2012 Share Posted June 11, 2012 does the sundial have to come off? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 11, 2012 Share Posted June 11, 2012 No. You should be able to remove the seal by driving a screwdriver through it and prying it out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
