Blights Posted June 27, 2014 Share Posted June 27, 2014 I have a 05 legacy 2.5. I just put a stock fog light kit in. Lights, stalk, relay (I think in the right place). Lights don't turn on. do I have to put a fuse in for them also? Yes I searched can't find nothing. Yes they are plugged in Link to comment Share on other sites More sharing options...
Drift Motion Posted June 27, 2014 Share Posted June 27, 2014 there is indeed a fuse on the driver side panel by the hood latch, do check that Link to comment Share on other sites More sharing options...
Blights Posted June 27, 2014 Author Share Posted June 27, 2014 It's factory on a 2.5 or a add on that's needed. Link to comment Share on other sites More sharing options...
Drift Motion Posted June 27, 2014 Share Posted June 27, 2014 check that fuse box see if it's empty most likely there is a empty slot from what you've described... Link to comment Share on other sites More sharing options...
Blights Posted June 27, 2014 Author Share Posted June 27, 2014 It's good. The fog lamp relay goes in the bottom left spot of the relay box right. Link to comment Share on other sites More sharing options...
Blights Posted June 29, 2014 Author Share Posted June 29, 2014 No one has installed fog before? All my fuses are good just put new bulbs in. Relay is new. Relay clicks when switch is turned on. Lights still don't work. Are any other relays needed? Link to comment Share on other sites More sharing options...
Bdubs Posted June 30, 2014 Share Posted June 30, 2014 Going to sound like a dumb question, but did you plug the harnesses together for each light behind the bumper? Link to comment Share on other sites More sharing options...
Blights Posted June 30, 2014 Author Share Posted June 30, 2014 Going to sound like a dumb question, but did you plug the harnesses together for each light behind the bumper? Def did that. After a couple of beers and diagnosing the wires it turned out the factory plug was corroded so bad it wasn't getting power to the bulbs. Rewired and it's all good to go. Now to find bulbs I like. Link to comment Share on other sites More sharing options...
