DrSpeed Posted January 30, 2012 Share Posted January 30, 2012 Car has 65,000 miles. In the last 2,000 miles, it's developed a squeak in the front suspension, when always under compression. Ex: hitting a speed bump at 3 mph that causes the suspenion to compress more than 1 inch. Happens regardless if it's one or both sides that compress. Not a high pitch squeek, sounds like a dulled, rubber on rubber with no lube squeek. I can't find it. Any advice? I didn't see any grease zirks under there. Stock suspension, Rallitek Swaway and endlinks. Thanks in advance. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
SARCruiser Posted January 30, 2012 Share Posted January 30, 2012 Sadly, all of the bushings on these cars are the "maintenance free" kind so no place to really lubricate something. Assuming from your post that it doesn't matter which side compresses it'll still squeak? My first thought would be a bad sway bar end link or bushing since that's the part of the suspension that "should" move regardless of the side compressing. I replaced both end links and bushings (actually the whole bar too) at 65k on my '06 and the stock ones were all in pretty bad shape. Since you have aftermarket sway and endlinks, I would still pull them and give them a thorough inspection before ruling them out. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 LCA bushings, sounds like a squishy rubber squeal in low speed hard bumps or the sway bar bushings need to be regreased Link to comment Share on other sites More sharing options...
DrSpeed Posted January 30, 2012 Author Share Posted January 30, 2012 Regreased the sway bar mounts (they have poly bushings with the own grease - I cleaned them up and threw in some Mobil 1 synthetic). How would I grease the LCA bushings, outside of removing the LCA's and pushing them out with a press? BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 lol lca bushings are not greasable. they are disposable. lifespan of 50k miles. get whitelines Link to comment Share on other sites More sharing options...
mustangendsley Posted January 30, 2012 Share Posted January 30, 2012 Maybe your struts are done. Mine are and they diff squeek. Link to comment Share on other sites More sharing options...
DrSpeed Posted January 30, 2012 Author Share Posted January 30, 2012 The dampening on the struts on there, I'll check again tonight. As for the LCA bushings, do both front and rear? http://www.whiteline.com.au/product_detail4.php?part_number=W0506 http://www.whiteline.com.au/product_detail4.php?part_number=W53353 Anyone got a write up, and any vendors that sell both in a kit? BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 http://www.infamousperformance.net/servlet/the-252/Whiteline-Subaru-Legacy-GT/Detail front inners are very unecessary, oem ones never wear out, and in actuality are more of a pita to press out than the round ones. Link to comment Share on other sites More sharing options...
DrSpeed Posted January 30, 2012 Author Share Posted January 30, 2012 Either way, SOB's gotta come out. Thanks for the tips...time to get the impact out... BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 either way, if you see dark spots or rips in your oem lcs bushings you know they're gone. i believe its a 59mm press cup thats used to press it out of the lca. Link to comment Share on other sites More sharing options...
DrSpeed Posted January 30, 2012 Author Share Posted January 30, 2012 good times. Now, do you wake up to this in the morning? http://legacygt.com/i/customavatars/avatar39424_89.gif BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted January 30, 2012 Share Posted January 30, 2012 I would replace both bushings while you have the lca off. Do it once. IMO the offset positive caster lca bushings (hockey puck sized ones) are one of my favorite suspension mods to the car. As Myles from RCE has told me before, "caster is like sex and money, you can never have enough" Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 every time i close my eyes she is next to me, yes Link to comment Share on other sites More sharing options...
DrSpeed Posted January 30, 2012 Author Share Posted January 30, 2012 Yep, figured if I had the whole sumbich apart, knock out both of them, especially when the front one is only 40 clams. Eyes closed? Moar worried about where the other hand is.. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 one of my best friends is the foreman at a subaru dealer and he pressed out the lca's for me in his machine, he said the smaller round ones are a BITCH because of the inability to stabilize the arm good Link to comment Share on other sites More sharing options...
FJuan Posted January 30, 2012 Share Posted January 30, 2012 lol lca bushings are not greasable. they are disposable. lifespan of 50k miles. get whitelines This. front inners are very unecessary, oem ones never wear out, and in actuality are more of a pita to press out than the round ones. If you're going to take off the LCA, I recommend replacing the inners with Whiteline. I did mine and it made a nice improvement in turning response. Took mine down to a machine shop and they pressed all 4 out/in for $30 bucks. Well worth it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
DrSpeed Posted January 30, 2012 Author Share Posted January 30, 2012 Can you guys confirm both the bushings that I need are: KCA334 W0506 BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
FJuan Posted January 30, 2012 Share Posted January 30, 2012 Those are correct. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
DrSpeed Posted January 30, 2012 Author Share Posted January 30, 2012 Man, what I would give up to be the meat in the BMX's and F1's avatar sandwich. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
FJuan Posted January 30, 2012 Share Posted January 30, 2012 This ones on the house. http://legacygt.com/i/customavatars/avatar39424_89.gifhttp://legacygt.com/i/customavatars/avatar30799_1.gifhttp://legacygt.com/i/customavatars/avatar13509_6.gif My wife's balls are delicious. Link to comment Share on other sites More sharing options...
bmx045 Posted January 30, 2012 Share Posted January 30, 2012 :not bad: Link to comment Share on other sites More sharing options...
DrSpeed Posted January 31, 2012 Author Share Posted January 31, 2012 nom nom nom.... BMW - the previous one was better. switch back. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
FJuan Posted January 31, 2012 Share Posted January 31, 2012 BMX My wife's balls are delicious. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted January 31, 2012 Share Posted January 31, 2012 You can also melt the small ones out with a torch. Link to comment Share on other sites More sharing options...
FJuan Posted January 31, 2012 Share Posted January 31, 2012 Nice one DrSpeed. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
