PortCityLGT Posted October 27, 2014 Share Posted October 27, 2014 Hi all, I'm getting conflicting answers on here and other Legacy forums for each of these questions: 1) Are the 14mm Eibach camber bolts the correct application for an '05 Legacy? 2) Should they be installed in the upper or lower location? If lower, should the stock upper eccentric bolt be left in place or be replaced with a fixed bolt? 3) Should the head of the bolt be facing the front or rear of the vehicle? Sorry for asking questions which have all been answered before. Would just like some consistency in the responses. Link to comment Share on other sites More sharing options...
PortCityLGT Posted October 27, 2014 Author Share Posted October 27, 2014 Alright. I think my google-fu pulled through. Looks like the Eibach 14mm is ok to use, just not listed under the applications list. And following the advice on those thread: http://www.iwsti.com/forums/gr-suspension-handling-stiffening/239752-right-position-camber-bolt.html I'll be moving it to the bottom, leaving the stock eccentric bolt in the top. Still not 100% on the bolt orientation, but I have a feeling the difference is negligible. Hope this helps anyone else who may be as confused as I was! Link to comment Share on other sites More sharing options...
