anyone know how to replace this part ?
the car came with a gash in the drivers side window rubber liner piece . i have a replacement part for it but dont know how to get access to it . if anyone could point me the right way, i`d greatly appreciate it .http://img.photobucket.com/albums/v466/lilvietkid91/P1020630.jpg
well, they gave it to me for free when we bought the car , so i dont know how much it is.
http://img.photobucket.com/albums/v466/lilvietkid91/P1020632.jpg
http://img.photobucket.com/albums/v466/lilvietkid91/P1020633.jpg
http://img.photobucket.com/albums/v466/lilvietkid91/P1020634.jpg
There should be no need to take the window out, and there will be no screws.
Those clips on the trim will snap into holes in the sheet metal inside at the top of the door. If you put the window all the way down you should be able to gently snap the existing one off. Once that is off check to make sure there are no clips left broken in the mounting holes, slide the new down into the crack and clip it in.
I have done this on my 07 Envoy, the part looked very similar. The trick is to be patient and not force anything.
I've had one of those replaced ( part of an insurance thing with other damage). And they did it pretty quickly. I wasn't there watching but they described it similar to how boostedcuda described.
It should snap in, once you get the old one out.
My guess is you should be able to pull that out with just your fingers. If any of the clips are broken you may need a flat head screwdriver to get them out of the indentions in the sheet metal.
I am also interested in what this piece goes for two of mine are messed up from when I bought the car, pretty sweet they hooked you up with it for free.
i just found a thread with the prices and partnumbers for those parts .
http://legacygt.com/forums/showthread.php/does-anyone-know-part-these-piecesi-121448.html
i also found out that the end of the rubber piece that is nearest to the rear door has a hole where a screw secures it into place. sooo, i think you`d probably have to take apart the door a bit to change out this part .
