ycpgirl88 Posted December 9, 2008 Share Posted December 9, 2008 Hi, I have a 2004 Subaru Legacy, and today I stupidly was trying to pry the thing off with tiny screwdrivers, it was working til I noticed it looked like major extra adhesive around the center, maybe a bolt there? I don't know. I just want to get it off to possibly change the background color. Help! Link to comment Share on other sites More sharing options...
Gmoe Posted December 9, 2008 Share Posted December 9, 2008 Not sure if that gen has a screw behind it or not. Remove the grille and take a look? 05+ has nothing but a ton of double sided sticky tape. Link to comment Share on other sites More sharing options...
ycpgirl88 Posted December 9, 2008 Author Share Posted December 9, 2008 how would i get the grill off to check it? Link to comment Share on other sites More sharing options...
Siper2 Posted December 9, 2008 Share Posted December 9, 2008 Most Subie front badges were always attached with tape. Take a small flathead screwdriver, and GENTLY see if you can pry up the edge. But if you want to check first, there's instructions on the site here for how to remove the grille. Link to comment Share on other sites More sharing options...
ycpgirl88 Posted December 9, 2008 Author Share Posted December 9, 2008 i actually did the like smallest flat head and it was coming off around the edges but the center was being way stubborn so i stopped. i'll check for the removing grille directions Link to comment Share on other sites More sharing options...
markbrotens Posted December 9, 2008 Share Posted December 9, 2008 Use a heat gun or hair dryer to heat up the badge for a couple of minutes. The tape should let go a lot easier. Link to comment Share on other sites More sharing options...
ycpgirl88 Posted December 10, 2008 Author Share Posted December 10, 2008 thanks i'll give that a try Link to comment Share on other sites More sharing options...
scoobydoobie Posted December 10, 2008 Share Posted December 10, 2008 use a heat gun or hair dryer to heat up the badge for a couple of minutes. The tape should let go a lot easier. +1 Link to comment Share on other sites More sharing options...
