Hecubus Posted June 24, 2014 Share Posted June 24, 2014 This post is just isn't so much technical, but curious to what anyone else has experienced this. My 07 Legacy recently lost all power. I got misfire codes on cylinder 2 and 4, and a code about Low Engine Idle (don't remember exactly). Long story short, the insides of my front Cat have disintegrated. I pulled off the mid pipe and a few big chunks and tons of dust fell out. After putting the mid pipe back on, the car is now drivable, but with decreased power still. So I'm guessing the rear cat is clogged too. I have a new front cat on the way, and probably soon a rear one too. I've never heard of the insides of a Cat deteriorate like that. Anyone else? Link to comment Share on other sites More sharing options...
kirshnerd Posted June 24, 2014 Share Posted June 24, 2014 If your car is stock, check your downpipe cat too. You may want to check your turbo and see if its all good as well. If your downpipe cat breaks down and blows into your turbo you could likely have serious problems. Link to comment Share on other sites More sharing options...
Hecubus Posted June 24, 2014 Author Share Posted June 24, 2014 No turbo. The downpipe (manifold) is the one I'm going to be replacing. Link to comment Share on other sites More sharing options...
rob-2 Posted June 24, 2014 Share Posted June 24, 2014 Should have an 8 year warranty. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2014 Share Posted June 24, 2014 ^ that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LongHiway Posted June 24, 2014 Share Posted June 24, 2014 Did you pull any of the exhaust heat shields off? Link to comment Share on other sites More sharing options...
Hecubus Posted June 24, 2014 Author Share Posted June 24, 2014 All the heat shields are still in place. Link to comment Share on other sites More sharing options...
Hecubus Posted June 24, 2014 Author Share Posted June 24, 2014 Subaru Warranty is 8yr/80K and I'm at 147K. Good suggestion though. Link to comment Share on other sites More sharing options...
LongHiway Posted June 24, 2014 Share Posted June 24, 2014 In Mass they had to extend the warranty to 10 years, maybe 120 K - I forgot. But, I got a free replacement at around that. Link to comment Share on other sites More sharing options...
