burnout8488 Posted October 6, 2010 Share Posted October 6, 2010 Is there a procedure specified for retorquing head bolts? I've got 103,000mi and have noticed a VERY small seepage of oil coming out of them. I don't plan on replacing them as its extremely minor - its not even close to leaking on the ground yet. I've seen with other cars that there is a procedure to retorque the heads after a certain amount of miles. Should I just retorque to factory specs as listed in the FSM? Sometimes its different if the head bolts have not been removed, I just want to make sure. Link to comment Share on other sites More sharing options...
Osei Posted October 7, 2010 Share Posted October 7, 2010 Never heard of a retorque procedure for these engines. Mileage? Perhaps its time to replace the HGs. Can't think of any reason why retorquing should hurt, unless the gaskets are going bad. O. Link to comment Share on other sites More sharing options...
GTTuner Posted October 7, 2010 Share Posted October 7, 2010 How can you see the head bolts leaking? They are under the valve cover. You must mean the head gasket? If they are leaking oil you need head gaskets. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 7, 2010 Share Posted October 7, 2010 Or do you mean the valve cover bolts are leaking ? If so just snug them up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Yamarocket630 Posted October 7, 2010 Share Posted October 7, 2010 Head bolts are torque to yield and cannot be retorqued as such. +1 on you probably saw seepage from the valve covers Link to comment Share on other sites More sharing options...
burnout8488 Posted October 7, 2010 Author Share Posted October 7, 2010 Sorry, I forgot to specify. There is a VERY small seepage coming out of the headgaskets, only on the bottom of the engine. Valve cover gaskets, tube seals, and bolt gaskets are fine. I wasn't sure if the head gaskets were TTY bolts or not. Thanks for the info guys Link to comment Share on other sites More sharing options...
