lolegacy. Posted November 5, 2012 Share Posted November 5, 2012 Bought a new bulb, but it's obvious after inspection the turn signal bulb socket is crapped out (rusty/junky) Any way to sort out a new one? thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted November 5, 2012 Share Posted November 5, 2012 Contact one of the dealer vendors from the VENDOR link above. Or take a pices of sand paper and remove the corrosion. Spray it with some contact cleaner from Radio Shack. Or ask one of us that happen to have one hanging in the shed, if I'd cut the wire and send you the socket. I bought a new tail light for my wagon after I cracked the lens last year. The new lens came with the harness. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wera832 Posted November 5, 2012 Share Posted November 5, 2012 From personal experience , take the bumper off - that wiring is a real pain to get to wiht the bumper on - Link to comment Share on other sites More sharing options...
Rooster Posted November 6, 2012 Share Posted November 6, 2012 Not sure what type of bulb it is or anything, but when I had a socket rust out badly in my RS I went and basically bought just a socket at an autoparts store. With some work, fit it in the old housing. Worked great, not sure if you can do something similar with the legacy or not. Link to comment Share on other sites More sharing options...
lolegacy. Posted November 6, 2012 Author Share Posted November 6, 2012 I figured I could just cut/sauder the wires back in. I may tackle it after winter with new headlamps as well. Link to comment Share on other sites More sharing options...
