Pijanica84 Posted October 23, 2010 Share Posted October 23, 2010 I'm looking from some help from all the suspension guru's on here. Here's my problem. Noticed about a month ago whenever I make a left turn where my wheel is cut more than ~30% I hear a grinding/rubbing noise coming from the front left wheel well. It occurs only when I make left hand turns and is confined to that area. I don't know it if could be the brakes or if it is due to the suspension. I am replacing installing new pads and rotors next week and would like to take care of this while i have the car up and that area dis-assembled already. Thanks for your input guys! Link to comment Share on other sites More sharing options...
king_j Posted October 23, 2010 Share Posted October 23, 2010 is the car lowered? is the tire damaged form this? Link to comment Share on other sites More sharing options...
Pijanica84 Posted October 23, 2010 Author Share Posted October 23, 2010 No car is a completely stock 2005 LGT. Tire wear seems normal compared to the others. Link to comment Share on other sites More sharing options...
AZP Installs Posted October 25, 2010 Share Posted October 25, 2010 have you had the undertray off for anything? We've seen where the side clips are not re-attached and folks get a grinding noise at full lock. -mike Link to comment Share on other sites More sharing options...
