boss755 Posted March 19, 2013 Share Posted March 19, 2013 Hello people . last summer i installed the rallitek spring on my lgt 2005 with oem strut. It give a really nice 1"drop and better handling but still comfortable . but the problem is that i'm now rubbing fender with my 17x8 +40offset wheel with 225/45/17tire . is it normal ? I've read people with those spring getting big 18 " wheel with no rubbing Im not so Fan of rolling fender i would prefer get new wheels . But if anyone with rallitek spring can get me info about their wheels . i appreciate tks Link to comment Share on other sites More sharing options...
zenfamily Posted March 19, 2013 Share Posted March 19, 2013 I'm running rallitek spring/kyb (OEM) struts. I'm running 18x7.5 +45 offset with 225/45/18, and I have no rubbing. Are you running any spacers? Which fender is rubbing? Link to comment Share on other sites More sharing options...
Schubaru Posted March 19, 2013 Share Posted March 19, 2013 Im running 17X8's on Bilsteins with Rallitek's and havent had any issues. Link to comment Share on other sites More sharing options...
jkaszynski Posted March 20, 2013 Share Posted March 20, 2013 Wouldn't the Oem struts have too much travel since they're matched for a little bit higher spring? Link to comment Share on other sites More sharing options...
boxkita Posted March 20, 2013 Share Posted March 20, 2013 225/45/17 is a taller tire, and your offset is not optimal...which can lead to rubbing. Especially as your car gets older and parts start to settle. Reference XenonK's awesome thread on matching wheels/tires to your car. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boss755 Posted March 21, 2013 Author Share Posted March 21, 2013 Yeah its little bit too tall and little bit too offset . result: i rub over bump ,small or big. So i guess i will be looking for wheel that are less offset . more like oem offset . the problem is that most aftermarket wheel are +48 or less . I know prodrive used to do +53offset . but i check on their website and they said that they dont do part for street car anymore. Link to comment Share on other sites More sharing options...
boss755 Posted March 21, 2013 Author Share Posted March 21, 2013 Mm actually it said that they dont sell them anymore . Link to comment Share on other sites More sharing options...
boxkita Posted March 22, 2013 Share Posted March 22, 2013 Mm actually it said that they dont sell them anymore . Money is probably an object for you. However, every wheel company will make you a set of wheels, even if they have been discontinued. When they said they dont make them anymore, they really mean "its not profitable to make these wheels anymore". Pay their asking price (no low balls) and they will make them for you. You'll probably have to buy more than 1 set. Enkei will make custom wheels as long as you buy them 40 at a time. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
06legsleeper Posted March 22, 2013 Share Posted March 22, 2013 im running kyb struts, s tech spring,s ... 18x8 40 offset rims ..225/40 tire .. i did a little roll all around and i dont rub at all .. also maxed the stock front camber bolts .. -1.4ish ... handles great....and no rub as said above about the tire height .. if you went to a lower sidewall you might solve your problem Link to comment Share on other sites More sharing options...
boss755 Posted March 24, 2013 Author Share Posted March 24, 2013 Yeah money is a concern for me since im now ahappy father of a 3weeks old daughter. so i need a solution to be able to drive my LGT. the main problem right now is that 2 of my oem wheel are curb and it makes the tire deflated. i loose about 10 psi per week . but i might have find a solution if my Mathematic is rightIshould be good with the 2011 WRX wheels . It has +53 offset . 17x8 . so tell me if im wrong but the tire should be only 2 mm closer to the fender compare with +55 oem. the wheels are 17x8 so the wheel are gonna be 13 mm closer to the fender and 9 mm closer to the suspension . Since 1 "=22 MM.. i might have a deal on WRX wheels but i will have to use shipping so i dont want be wrong . Link to comment Share on other sites More sharing options...
06legsleeper Posted March 25, 2013 Share Posted March 25, 2013 yeah you will be fine with the wrx wheels my buddy has them on his lgt with no issues at all Link to comment Share on other sites More sharing options...
boss755 Posted March 25, 2013 Author Share Posted March 25, 2013 Cool . Good to hear that . tks peops Link to comment Share on other sites More sharing options...
