High Beam Alignment
Corny357
I adjusted my low beams today as per our sticky up top on how to properly align your headlights, but noticed that when the low beams were in proper adjustment/alignment/whatever, the passenger's side high beam was quite a bit lower than the driver's side. I cranked the passenger's side adjustment knob way up just to see what would happen, and of course, the high beams were properly aligned then, but the low beams were obviously way off. I have it set back so that the low beams are proper for now, but I'm not sure what to do about the high beam now...
Brandon
There is no separate high beam adjustment, which is why I was perplexed. Oddly enough, I just went out a second ago and literally switched the left bulb to the right and the right bulb to the left and they are even/aligned now.
:confused::confused::confused:
