specialB Posted June 11, 2012 Share Posted June 11, 2012 Was coming home from WBM today following an X5 M (damn they're quick) and picked up a nasty misfire on cyl 3. tried swapping the coil packs over and it stayed on 3 so I pulled the plug... http://i3.photobucket.com/albums/y89/Max00racer/IMG956696.jpg regapped the plug and put it back in and it runs fine. I'm going to replace all four tomorrow because a bit of the ceramic broke off the tip and there's no way i'm leaving it in there like that Link to comment Share on other sites More sharing options...
Mr. Sinister Posted June 11, 2012 Share Posted June 11, 2012 Yikes. I'm surprised you put that back in, even just temporarily. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 11, 2012 Share Posted June 11, 2012 Were you able to keep up with the X5? Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 thats what happened to my plug when i busted the top ringland of my piston. ran fine for a week after then deteriorated as more lands ended up breaking from the missing chunk of crown. you should borescope the cylinder to check. something hit your plug physically. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 11, 2012 Share Posted June 11, 2012 thats what happened to my plug when i busted the top ringland of my piston. ran fine for a week after then deteriorated as more lands ended up breaking from the missing chunk of crown. you should borescope the cylinder to check. something hit your plug physically. Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 :shrug: Link to comment Share on other sites More sharing options...
robinlsb Posted June 11, 2012 Share Posted June 11, 2012 thats what happened to my plug when i busted the top ringland of my piston. ran fine for a week after then deteriorated as more lands ended up breaking from the missing chunk of crown. you should borescope the cylinder to check. something hit your plug physically. +1000:mad: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
specialB Posted June 11, 2012 Author Share Posted June 11, 2012 Were you able to keep up with the X5? the x5 and I were a dead even match but I wad only on pump gas. Would have been all rear view mirror had i been on corn. And yes I will def get a scope in that cylinder before I replace the plug tonight. I was very weary putting the plug back in but I had to make it to the ferry so I could get get home. Unfortunately nothing was open past six on a Sunday to source a new one Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 this is what bent my spark plug, a good ole hot spot- http://i1135.photobucket.com/albums/m636/MotiveHero/temporary-3.jpg Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 11, 2012 Share Posted June 11, 2012 Crossing fingers OP did not get what happened to bmx. Hopefully.. And props to you if the X5 had a twin turbo V8 with 550 hp (that's what wiki says..). I wonder if you pushed too hard.. Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 that damage did this to my plug- http://i1135.photobucket.com/albums/m636/MotiveHero/plug.png Link to comment Share on other sites More sharing options...
specialB Posted June 11, 2012 Author Share Posted June 11, 2012 Crossing fingers OP did not get what happened to bmx. Hopefully.. And props to you if the X5 had a twin turbo V8 with 550 hp (that's what wiki says..). I wonder if you pushed too hard.. I really hope I didn't do the same damage as bmx I'll be really torn up. And holy hell I didn't know that is what those things are packing no wonder. And yea I was pushing her pretty hard. Yet then again I drove a good thousand miles this weekend pretty hard. Keep posted for pics from my buddies snap on scope later tonight and keep your fingers crossed for me Link to comment Share on other sites More sharing options...
WhiskeyTango Posted June 11, 2012 Share Posted June 11, 2012 the x5 and I were a dead even match but I wad only on pump gas. Would have been all rear view mirror had i been on corn. :lol::lol: Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 the x5 M has 555hp. the regular x5 is probably a dog. so, in that case, it would've still beaten you if you were on corn. Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 Engine 3.0 L 272 hp I6 3.0 L 306 hp I6 Single Turbo 3.0 L 265 hp Diesel TT I6 4.8 L 355 hp V8 4.4 L 555 hp V8 Twin Turbo Transmission 6-speed automatic; 8-speed Prundletronic prundletronic? damn, and i thought the 5eat was ghey. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted June 11, 2012 Share Posted June 11, 2012 I dont care if it was the M or even a X5 his statement is stupid Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 attempting to keep up with an SUV is plain stupid, unless you're trying to draft for more mpg's Link to comment Share on other sites More sharing options...
specialB Posted June 11, 2012 Author Share Posted June 11, 2012 Why not whiskey? If I were dead even on pump gas and run another hundred crank horse on corn... the X5 M weighs in at close to 5300lbs while i'm only at 3400. Some simple math can tell you that the crank power to weight ratio of the BMW is 9.55lbs per horse. While me on corn is about 7.55 and on pump gas is about 9.7 (almost a dead match) as I experienced on the highway. But please do tell me why my comment is stupid or wrong maybe i'm missing something? Link to comment Share on other sites More sharing options...
1055 Posted June 11, 2012 Share Posted June 11, 2012 Racing on the highway makes this whole story irrelevant. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted June 11, 2012 Share Posted June 11, 2012 Lets put the street racing aspect aside. Any statment that says if bla bla bla I would have won. you know if I was running 100oct I might have beat that guy. Its stupid plan and simple. Well you werent so guess what...you didnt. Link to comment Share on other sites More sharing options...
Lardo420 Posted June 11, 2012 Share Posted June 11, 2012 prundletronic? damn, and i thought the 5eat was ghey. grundletronic OP i hope you didnt BMX your motor Link to comment Share on other sites More sharing options...
HipsterDoofus Posted June 11, 2012 Share Posted June 11, 2012 oh, Im in Link to comment Share on other sites More sharing options...
bmx045 Posted June 11, 2012 Share Posted June 11, 2012 wait, his info says cornfed, was he running pump gas with an e85 tune? = det Link to comment Share on other sites More sharing options...
specialB Posted June 11, 2012 Author Share Posted June 11, 2012 Lets put the street racing aspect aside. Any statment that says if bla bla bla I would have won. you know if I was running 100oct I might have beat that guy. Its stupid plan and simple. Well you werent so guess what...you didnt. Ok I agree with you here and I hate CT for having literally no corn in the whole state. For those of you who don't have it its seriously an addiction, the power gains are incredible. And no bmx I was running pump gas on my pump gas map for almost a thousand miles up until I ran into that issue. And lastly I know street racing is not condoned and there was no lining up or horn honks or diving through traffic. Was just following him and I knew when he was going WOT on nice clear straights of road Link to comment Share on other sites More sharing options...
HipsterDoofus Posted June 11, 2012 Share Posted June 11, 2012 So...you raced someone who wasn't even aware that they were racing? Link to comment Share on other sites More sharing options...
