suboogru Posted July 1, 2012 Share Posted July 1, 2012 Sorry i tried search and am just tired of reading. i want a catted cnt dp for my car and know i should get a tune. will i NEED an ap tuner because it will be bad for my car without it or is the tuner just for maximum performance? also will the cel come on with a high flow cat? sorry im sure this was asked before but i must not know how to word it for search or something. i currently have a lightweight pulley and catless uppipe installed on the car Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted July 1, 2012 I Donated Too Share Posted July 1, 2012 I seriously doubt you searched hard enough. Yes, you will need a tune if you get an aftermarket downpipe. Whether you decide to tune it with an Accessport or go opensource is up to you. Link to comment Share on other sites More sharing options...
turbodog Posted July 1, 2012 Share Posted July 1, 2012 Actually, as long as you are able to get the boost control adjusted (larger pill iirc) so that it is not overboosting, it will be just fine running on the stock tune. The change in the downpipe is trivial, and has no impact on anything aside from reduced back pressure / bellmouth hence the more open wastegate to keep boost in check. But allow me to assure you that everyone will say that I am completely wrong due to common knowledge while offering no substantial arguments to back their claims. IBTL. Link to comment Share on other sites More sharing options...
suboogru Posted July 1, 2012 Author Share Posted July 1, 2012 Obviously I didn't search hard enough clown or I wouldn't have had to ask, but thanks for answering. I'm no rocket surgeon so can you please explain why I need a tune. Link to comment Share on other sites More sharing options...
suboogru Posted July 1, 2012 Author Share Posted July 1, 2012 Sorry, clown is a term thrown around here at work a lot so it was a force of habit . Meant no disrespect by it. Also what is a larger pill iirc. I honestly don't know much about cars and never had a Subaru till this one Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 1, 2012 Moderators Share Posted July 1, 2012 subscribed for blown motor... Take your car to a full service speed shop that will install the parts and tune the car for you and you'll be fine. Enjoy stage 2. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 1, 2012 I Donated Share Posted July 1, 2012 Don't listen to Turbodog, he thinks it's dangerous to run tires at the manufacturer-recommended specs. Zero credibility on anything after that. Link to comment Share on other sites More sharing options...
1055 Posted July 1, 2012 Share Posted July 1, 2012 40+ psi or bust! Link to comment Share on other sites More sharing options...
Max Capacity Posted July 1, 2012 Share Posted July 1, 2012 The engine will flow more air with a DP, the tune must be adjusted so you have more fuel to go with the increase in air flow. If you don't the engine will run lean and burn valves. Where do you live ? may be one of us can recommend a local shop or tuner for you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
stocklgt Posted July 1, 2012 Share Posted July 1, 2012 You will need a tune. And you didn't search hard enough clown. Point is whether you tune using opensource or AP, you will need one. With AP you can use one of their pre-written stg 2 maps (called OTS or off the shelf search again), or with Opensource you can take your car to a dyno shop so they can tune it for you (search again) or data log yourself using a special cable (search again) and send the file out to an E-tuner such as Infamous (search again) to tune it for you. If you blow your motor bc you never tuned, who is the clown? I mean no disrespect of course... Link to comment Share on other sites More sharing options...
m sprank Posted July 1, 2012 Share Posted July 1, 2012 Actually, as long as you are able to get the boost control adjusted (larger pill iirc) so that it is not overboosting, it will be just fine running on the stock tune. The change in the downpipe is trivial, and has no impact on anything aside from reduced back pressure / bellmouth hence the more open wastegate to keep boost in check. But allow me to assure you that everyone will say that I am completely wrong due to common knowledge while offering no substantial arguments to back their claims. IBTL. WTF?!?! This guy again??? Please do not listen to anything said. I compare these posts to the "Mayhem" commercials. Link to comment Share on other sites More sharing options...
turbodog Posted July 1, 2012 Share Posted July 1, 2012 The engine will flow more air with a DP, the tune must be adjusted so you have more fuel to go with the increase in air flow. If you don't the engine will run lean and burn valves. Where do you live ? may be one of us can recommend a local shop or tuner for you. The MAF will still read accurately and the ecu will still fuel the engine properly. A very small improvement to the volumetric efficiency of the system is not going to change that, and will certainly not make it run lean, or even more lean. There are plenty of things that will make a car run lean, this is not one of them, aside from a possible danger of overboosting as mentioned above. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 1, 2012 I Donated Share Posted July 1, 2012 The MAF will still read accurately and the ecu will still fuel the engine properly. A very small improvement to the volumetric efficiency of the system is not going to change that, and will certainly not make it run lean, or even more lean. There are plenty of things that will make a car run lean, this is not one of them, aside from a possible danger of overboosting as mentioned above. So I take it you have tuned enough cars to know that the MAF does not need to be rescaled? Link to comment Share on other sites More sharing options...
suboogru Posted July 1, 2012 Author Share Posted July 1, 2012 You will need a tune. And you didn't search hard enough clown. Point is whether you tune using opensource or AP, you will need one. With AP you can use one of their pre-written stg 2 maps (called OTS or off the shelf search again), or with Opensource you can take your car to a dyno shop so they can tune it for you (search again) or data log yourself using a special cable (search again) and send the file out to an E-tuner such as Infamous (search again) to tune it for you. If you blow your motor bc you never tuned, who is the clown? I mean no disrespect of course... Maybe you should learn how to read. I said I didn't search real hard. I work 60+ hours a week and don't have time to sift through every post. Stop camping out in your parents basement playing on the computer, your mom called you up to dinner 20 minutes ago. CLOWN Link to comment Share on other sites More sharing options...
suboogru Posted July 1, 2012 Author Share Posted July 1, 2012 The engine will flow more air with a DP, the tune must be adjusted so you have more fuel to go with the increase in air flow. If you don't the engine will run lean and burn valves. Where do you live ? may be one of us can recommend a local shop or tuner for you. I'm just outside of York pa Link to comment Share on other sites More sharing options...
lol slow Posted July 1, 2012 Share Posted July 1, 2012 you guys are haters, turbodog put an up pipe, down pipe, exhaust, intake on for me and told me no need for tune, car runs great, ran a 14.9 at 93mph. yes, you'll need a tune, one for safety, 2 because that way you'll get the full potential of it. I say just get a cobb AP. Link to comment Share on other sites More sharing options...
suboogru Posted July 1, 2012 Author Share Posted July 1, 2012 Thanks. I'm gonna order the downpipe and the Cobb ap when things at work settle down. No point in ordering them just to sit around in the boxes Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 1, 2012 Moderators Share Posted July 1, 2012 Can turbodog be banned for being a know-nothing-know-it-all turd? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted July 1, 2012 I Donated Too Share Posted July 1, 2012 I'm just outside of York pa So I'm assuming you have a low IQ, wear sleeveless, white trash t-shirts, and enjoy the musical stylings of ICP? (hence the pervasive use of the word 'clown') Link to comment Share on other sites More sharing options...
suboogru Posted July 2, 2012 Author Share Posted July 2, 2012 U mite bee write. eyem knot shore ezacly wut u sayd thow. wii ant az cleaver az them peepholes frum arownd playces lyke AROUND wear them stayt flaggs r texico syns Link to comment Share on other sites More sharing options...
suboogru Posted July 2, 2012 Author Share Posted July 2, 2012 Hey this is fun.........you and me just CLOWNING around Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted July 2, 2012 I Donated Too Share Posted July 2, 2012 http://media.merchantcircle.com/16535166/inbreeding_full.jpeg Link to comment Share on other sites More sharing options...
turbodog Posted July 2, 2012 Share Posted July 2, 2012 you guys are haters, turbodog put an up pipe, down pipe, exhaust, intake on for me and told me no need for tune, car runs great, ran a 14.9 at 93mph. yes, you'll need a tune, one for safety, 2 because that way you'll get the full potential of it. I say just get a cobb AP. Errrr, no idea what this guys is talking about. Link to comment Share on other sites More sharing options...
No DRFT Posted July 2, 2012 Share Posted July 2, 2012 Maybe you should learn how to read. I said I didn't search real hard. I work 60+ hours a week and don't have time to sift through every post. Stop camping out in your parents basement playing on the computer, your mom called you up to dinner 20 minutes ago. CLOWN I have no control over drippie. Link to comment Share on other sites More sharing options...
turbodog Posted July 2, 2012 Share Posted July 2, 2012 So I take it you have tuned enough cars to know that the MAF does not need to be rescaled? Scaling the MAF has nothing do to with this, and furthermore has nothing to do with a stage one or two tune on a stock intake. Nothing has changed about how air is measured. I've seen this done on a subaru, with logs and WBO2, and it works fine, the only thing that needs adjustment is the boost control system due to the reduced back pressure of the downpipe. The need for a tune with a downpipe is completely a myth. However, you are not likely to make much more power. God forbid anybody was to install a MBC on one of these cars, that would be denounced as barbaric. LOL. Link to comment Share on other sites More sharing options...
