Spec B 127 Posted November 12, 2009 Share Posted November 12, 2009 Well I searched to no avail so I figured I would throw out the question: Will a stock and/or lightened STi flywheel work on our LGT? I know the stock WRX flywheel will bolt right in. Would I then have to use a STi sepcific clutch and pressure plate (I would assume so)? I can pick up a stock STi flywheel here locally pretty cheap so I thought I run it past the forum. TIA. Link to comment Share on other sites More sharing options...
fonts Posted November 14, 2009 Share Posted November 14, 2009 I do NOT believe it would work since the STi has a 6MT and the 06 SpecB was running a 5MT. STi flywheel works with 07+ SpecB. WRX flywheel works with LGT (or 06 SpecB). Link to comment Share on other sites More sharing options...
