OBPLegacyGT Posted June 28, 2013 Share Posted June 28, 2013 Every once in a while (and seems to do it more when its hot), my radio stack display will turn off (as well as my HVAC display). When this happens, the buttons don't work either. The only way that I know of to fix it is to press on the plastic fascia until the display works again. I have a 2008 LGT, and it isn't modded at all. It is the stock radio, and I don't know if it had a satellite radio at one point or not. My sisters car does the same thing, too. She has a 2007 Legacy Limited. Any thoughts? Link to comment Share on other sites More sharing options...
rouar Posted June 29, 2013 Share Posted June 29, 2013 Common issue, I just push the faceplate between the BAL/AUDIO buttons when it happens. Fix: http://legacygt.com/forums/showthread.php/radio-display-fix-142191.html Link to comment Share on other sites More sharing options...
