Jack Giovo Posted September 10, 2013 Share Posted September 10, 2013 Will the same tire (215/50/17) mounted on a wider rim have an effect on the circumference of that tire. Link to comment Share on other sites More sharing options...
Drift Motion Posted September 10, 2013 Share Posted September 10, 2013 no Link to comment Share on other sites More sharing options...
Dbl_D718 Posted September 10, 2013 Share Posted September 10, 2013 Technically, yes, it would. But not enough to matter for anything, really. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
Drift Motion Posted September 10, 2013 Share Posted September 10, 2013 ^do explain if you are thinking about ride height/height of tire, that's a different thing... Link to comment Share on other sites More sharing options...
LatentWagen Posted September 10, 2013 Share Posted September 10, 2013 I think stretching the crap out of a skinny tire on a wide wheel is what he's talking about. You'd have an angled sidewall, so the tire must be closer do the wheel (making for a smaller diameter). But he answer is still basically no LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Drift Motion Posted September 11, 2013 Share Posted September 11, 2013 that will change the height of the tire, not the circumference... Link to comment Share on other sites More sharing options...
LatentWagen Posted September 11, 2013 Share Posted September 11, 2013 that will change the height of the tire, not the circumference... Changing the height of the tire = changing the circumference... a shorter circle has a smaller circumference. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Drift Motion Posted September 11, 2013 Share Posted September 11, 2013 i wanna see how you magically change the circumference of some rubber that has been formed to a shape without cutting/modifying it... Link to comment Share on other sites More sharing options...
Dbl_D718 Posted September 11, 2013 Share Posted September 11, 2013 I think stretching the crap out of a skinny tire on a wide wheel is what he's talking about. You'd have an angled sidewall, so the tire must be closer do the wheel (making for a smaller diameter). But he answer is still basically no This. The same amount of rubber will be there, but it'll be stretched/contorted a little differently. It would be measurably but insignificantly different. I was really just being a smart-ass though MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
Squad51 Posted September 11, 2013 Share Posted September 11, 2013 Changing the height of the tire = changing the circumference... a shorter circle has a smaller circumference. I guess it depends which circumference you are wanting to measure. Exterior (tread), lip, or interior. I would contend the lip measurement would change little enough on a stretched tire to be inconsequential, however on the same tire when the sidewall angle changes the exterior diameter of the tire should shrink, albeit probably very minimally. Link to comment Share on other sites More sharing options...
LatentWagen Posted September 12, 2013 Share Posted September 12, 2013 i wanna see how you magically change the circumference of some rubber that has been formed to a shape without cutting/modifying it... Burnouts LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
