SilverGSX Posted December 8, 2012 Share Posted December 8, 2012 Just looking at pictures I can't tell if this is totally normal or not. When your low beams are on, do your high beams glow dimly? I used the JDM harnesses spliced into the US wiring like all the write-ups say and yet when I see pictures of others setup I don't notice the same high beams glowing dimly when the low beams are on. It is making me run into issues when I try to wire in my DDM HIDs. Is this normal? or is something wrong here... Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 8, 2012 Share Posted December 8, 2012 Something is wrong. I had the same problem but I don't remember what was causing it. All I remember is that it took me hours and hours to figure it out. I had just wired something up wrong. I wish I could give you a better answer. Link to comment Share on other sites More sharing options...
SilverGSX Posted December 8, 2012 Author Share Posted December 8, 2012 Good times. It looks neat and I was hoping it'd stay working like that with HIDs but apparently not. After googling and lots of searching it looks like the highs are not supposed to be lit whatsoever when the lows are on, so something's awry. I hooked up the wiring like all the other diagrams show though, so I have no clue why it'd be doing this... power feeds power, high connected to high, low connected to low. Why is the high getting current when the low is on? Link to comment Share on other sites More sharing options...
twisty Posted December 10, 2012 Share Posted December 10, 2012 only thing i can think of is a weak or bad relay leaking power when its not supposed to. id switch the two relays (hi/lo) and see if the problem moves with it. Link to comment Share on other sites More sharing options...
SilverGSX Posted December 11, 2012 Author Share Posted December 11, 2012 One side was wired incorrectly. Red/blue to red and vise versa. Swapped those wires and problem solved. Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 11, 2012 Share Posted December 11, 2012 I told you something was wired wrong! The same thing happened to me. It sucked. I checked it over and over and over, lol. I'm glad you figured it out. Link to comment Share on other sites More sharing options...
