stinger44 Posted December 7, 2010 Share Posted December 7, 2010 What services do they perform at 30k miles? I have a 2010 Legacy 3.6R. Was wondering if it's critical and worth the cost, whatever that is. Thanks:) Link to comment Share on other sites More sharing options...
AZP Installs Posted December 7, 2010 Share Posted December 7, 2010 We do the following on our cars at 30k: http://azpinstalls.com/index.php?option=com_content&view=article&id=48&Itemid=79 For the 3.6R I don't think you need to do plugs at 30k like the 2.5i But otherwise it's the same stuff. Also on the newer cars I don't think you need to flush the coolant because they have the "blue" long life antifreeze. Essentially: Oil Change w/Filter Brake Flush Trans Drain/fill Diffy Drain/fill Air Filter Check on the brakes, belts, etc. -mike Link to comment Share on other sites More sharing options...
stinger44 Posted December 7, 2010 Author Share Posted December 7, 2010 We do the following on our cars at 30k: http://azpinstalls.com/index.php?option=com_content&view=article&id=48&Itemid=79 For the 3.6R I don't think you need to do plugs at 30k like the 2.5i But otherwise it's the same stuff. Also on the newer cars I don't think you need to flush the coolant because they have the "blue" long life antifreeze. Essentially: Oil Change w/Filter Brake Flush Trans Drain/fill Diffy Drain/fill Air Filter Check on the brakes, belts, etc. -mike Thanks, appreciate it. Link to comment Share on other sites More sharing options...
