mmarton Posted January 23, 2009 Share Posted January 23, 2009 I just tried unlocking my car (05 2.5i wagon) with the remote fob and it didn't work. I've noticed that it took some very firm presses to work lately, signaling tom me that perhaps the fob battery needs replacing. My question is, can I replace the battery and, if so, do I need to have the fob reprogrammed? Link to comment Share on other sites More sharing options...
Underdog Posted January 23, 2009 Share Posted January 23, 2009 If it is anything like my fob ('06 GT) then you can pry open the case and replace the battery, without needing to reprogram. The Crimson Dynamo Link to comment Share on other sites More sharing options...
kong Posted January 23, 2009 Share Posted January 23, 2009 This has been happening to me too lately. But I was going to see if I can use it as an excuse with the wife to get the new integrated key with fob instead. On a side note; do I need to worry about breaking anything should I decide to replace the battery and pry that sucker open? Link to comment Share on other sites More sharing options...
tbssubaru Posted January 23, 2009 Share Posted January 23, 2009 worst case scenario you can reprogram at home Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted January 25, 2009 Share Posted January 25, 2009 all you need is a CR2025 battery. pry the fob open from the fat end without the key ring and replace the battery. Link to comment Share on other sites More sharing options...
kong Posted January 26, 2009 Share Posted January 26, 2009 Hmmm, that sounds easy enough. Thanks. Link to comment Share on other sites More sharing options...
psbreen Posted April 19, 2009 Share Posted April 19, 2009 I wish I had been that lucky. I had the same basic problem, but it was the lock button. At first it would work about half the time, then it just quit altogether. A new battery didn't fix it so I pulled the circuit board out to take a look and found the LOCK switch (SW1) had come off the board. I've never tried to solder surface mount components, but figured it was dead anyway. I ended up using a 15 watt soldering pen with a tip that I filed to a needle point. It's been just over a week now and no problems. Sure beats $100+ for a new one. PSBreen Link to comment Share on other sites More sharing options...
