rayeve Posted August 29, 2013 Share Posted August 29, 2013 My wife had to stop in an emergency stop yesterday in her 2005 Legacy to avoid broadsiding an idiot. She says when she then put her foot on the accelerator, the car bogged very badly as if it were going to die before finally accelerating normally. It's only done this on this one occasion. Anyone got any idea of what could cause this. (The car if a non-turbo with about 130,000 on it. But it's in good tune otherwise). Link to comment Share on other sites More sharing options...
12sechatch Posted August 29, 2013 Share Posted August 29, 2013 possibly something to do with the vacuum lines and the brake booster. brake booster uses vacuum. loose/unhooked vacuum lines can cause the symptoms you speak of. I'm just guessing.... Link to comment Share on other sites More sharing options...
jp233 Posted August 29, 2013 Share Posted August 29, 2013 5MT or 4EAT ? If 5MT, brakes only or did she mash the clutch. If no clutch, it would be more obvious Link to comment Share on other sites More sharing options...
Max Capacity Posted August 29, 2013 Share Posted August 29, 2013 How much gas was in the tank ? It's a wild guess. If she dose that more often, the ECU will re-learn that and compensate for it... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rayeve Posted August 29, 2013 Author Share Posted August 29, 2013 to Senior Member, No, it's an AT. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 29, 2013 Share Posted August 29, 2013 Sticking caliper, most likely the rear. Link to comment Share on other sites More sharing options...
frank_ster Posted August 30, 2013 Share Posted August 30, 2013 it can be the "bucket" in the gas tank just got most of the gas spilled out of it. can take a few seconds before the jets get it filled back up again. the pre 93 cavaliers and gm's were realy bad for that. under hard deceleration or accelerations the pumps can get uncovered and suck air. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
