xxirish83x Posted September 11, 2013 Share Posted September 11, 2013 Long story short i need a clutch recommendation car is in the shop so time is of the essence Car used as a daily driver and i dont race or mess around all too much if at all.... HP goal is 325ish when complete Parts list: Cobb Access Port running stage 2 map (i know i need a complimentary tune, im waiting on aquiring more parts) Cobb Downpipe Cobb up pipe SPT Intake BNR Supercars 18g Turbo Infamous Oil Lines for turbo Cobb BPV Thanks for any input. Link to comment Share on other sites More sharing options...
CapnJack Posted September 11, 2013 Share Posted September 11, 2013 I have a Clutchmasters FX300 in mine. It feels like stock and will hold up better with what you are running over the stock clutch. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 11, 2013 Moderators Share Posted September 11, 2013 I have an FX350 in mine and it chatters like a bitch. YMMV. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
idiot4hire Posted September 11, 2013 Share Posted September 11, 2013 Clutch masters fx350: is a good clutch I use on my car good pedal feel way better then my spec clutch will need a single mass flywheel or lwfw ACT: the most popular choice, good reviews. Will need a single mass flywheel or lwfw Spec: Most people don't have good results with them. You can reuse your duel mass but not recommended Comp clutch: they are out there have not read any feed back. Come as a clutch/flywheel package. Link to comment Share on other sites More sharing options...
idiot4hire Posted September 11, 2013 Share Posted September 11, 2013 I have an FX350 in mine and it chatters like a bitch. YMMV. Mine recently stopped chattering Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 11, 2013 Moderators Share Posted September 11, 2013 Yeah, mine seems to be slowly getting better I guess. Maybe driver error, lol "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
xxirish83x Posted September 11, 2013 Author Share Posted September 11, 2013 What parts do i have to order/replace when getting a clutch replaced? The mechanic told me Clutch pressure plate & disc, throwout bearing, pilot bearing does that sound about right? Link to comment Share on other sites More sharing options...
ras06LGT Posted September 11, 2013 Share Posted September 11, 2013 I would recommed the FX350 for light pedal effort and great driveability. Check the FX350 thread in the Trans section. You will be looking to replace: Friction disc Pressure plate TOB bearing Flywheel (unless replacing with OEM or Spec clutch, then depends on current FW condition) Pilot bearing TSK3 trans snout sleeve kit (comes with TOB) usually recommended Might need replacing: (unlikely, but possible) Clutch fork (if cracked/broken) Slave cylinder (if leaking) MC (again, if leaking) Lines from MC to slave (if cracking) Link to comment Share on other sites More sharing options...
Danteneon Posted September 11, 2013 Share Posted September 11, 2013 I have an FX350 in mine and it chatters like a bitch. YMMV. QFT. It scared me a bit I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
Burba88 Posted September 11, 2013 Share Posted September 11, 2013 ACT clutch SMFW TSK-3 kit. prefect. KMT Tuned Link to comment Share on other sites More sharing options...
urfsin Posted September 11, 2013 Share Posted September 11, 2013 I have a clutch masters FX300 and it's quiet as stock, not chattering or anything. This is with the WRX single mass flywheel. The pedal is LIGHTER than stock, but the engagement is much more abrupt / grabby. Reverse can be a little tricky for me. I had a Spec stage 2 before this and it only lasted about 30,000 miles....I think because I did not resurface my stock flywheel when I put it in. I only gave it a light sanding / roughing up and cleaning. Slide It Sideways Link to comment Share on other sites More sharing options...
robitrice Posted September 11, 2013 Share Posted September 11, 2013 exedy stage 1 with wrx fw Link to comment Share on other sites More sharing options...
xxirish83x Posted September 12, 2013 Author Share Posted September 12, 2013 I have a clutch masters FX300 and it's quiet as stock, not chattering or anything. This is with the WRX single mass flywheel. The pedal is LIGHTER than stock, but the engagement is much more abrupt / grabby. Reverse can be a little tricky for me. I had a Spec stage 2 before this and it only lasted about 30,000 miles....I think because I did not resurface my stock flywheel when I put it in. I only gave it a light sanding / roughing up and cleaning. I ended up going with the spec clutch kit... I didn't want to change my flywheel out. I got 100k out of stock clutch. Plan on getting a new car in a year or so.... Thanks for the input everyone Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 12, 2013 Moderators Share Posted September 12, 2013 Mine recently stopped chattering How many miles? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
idiot4hire Posted September 12, 2013 Share Posted September 12, 2013 About 5k easy miles, maybe a little less Link to comment Share on other sites More sharing options...
Max Capacity Posted September 12, 2013 Share Posted September 12, 2013 I ended up going with the spec clutch kit... I didn't want to change my flywheel out. I got 100k out of stock clutch. Plan on getting a new car in a year or so.... Thanks for the input everyone If it makes you feel better, I'm the one that get's great service out of my Spec clutches. My 2+ was great when I replaced it after 80,000 miles. It chattered every now and then when the weather was right for it, much like my old stock one did. My current Spec 2 is great, over 20,000 miles. Has never chattered. Works great. I had another member drive the car last night, he's going to order a Spec 2. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xxirish83x Posted September 19, 2013 Author Share Posted September 19, 2013 after the mechanic took the trans down he noticed the underlying issue that caused the failure.... the ******* clutch fork cracked! ended up replacing the clutch anyways and now its super easy to press down... its kinda weird. almost like pressing down the gas pedal Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted September 19, 2013 Share Posted September 19, 2013 nm Tits mcgee Link to comment Share on other sites More sharing options...
xxirish83x Posted September 26, 2013 Author Share Posted September 26, 2013 http://i5.photobucket.com/albums/y174/xxirish83x/photo_zps094b44c8.jpghere is a picture of the clutch and the broken fork i replaced Link to comment Share on other sites More sharing options...
sodium303 Posted September 27, 2013 Share Posted September 27, 2013 i know DMFW's aren't supposed to be resurfaced according to the stearlership, But i went on ahead and resurfaced mine with a stock subaru sachs clutch kit. No issues at all what so ever....yet. Don't see why we cant resurface them, i havent found information as to why yet. Link to comment Share on other sites More sharing options...
Sicotic Posted September 27, 2013 Share Posted September 27, 2013 I need a clutch as well, mine finally started slipping. I'm stage 3 on stock clutch hahaha. i have a WRX flywheel BNIB, what clutch should i get with this? Or does anyone have some laying around? Link to comment Share on other sites More sharing options...
