RedHorizon Posted February 6, 2010 Share Posted February 6, 2010 Hey, Got stuck in the snow today, did a little wheel spinning and threw a Check engine code P0700, “Request AT mil on”. Also got another code something along the lines of "speed position sensor”, was able to clear that code. However, I was unable clear the first code, P0700, with the AP. Any insite is appreciated. Thanks Link to comment Share on other sites More sharing options...
Slickvic Posted February 7, 2010 Share Posted February 7, 2010 It simply means that the engine computer has noticed that the transmission computer has a stored diagnostic trouble code in it. This causes the ECM (engine computer) to turn the check engine light on. You will need to have the TCM (transmission computer) checked for codes to know what to diagnose. From what I have read in other forums about this code it is sometimes triggered by a rapid change in transmission fluid temperature. (Perhaps from spinning your wheels?) Link to comment Share on other sites More sharing options...
RedHorizon Posted February 7, 2010 Author Share Posted February 7, 2010 Thanks, I take it by the dealer. Link to comment Share on other sites More sharing options...
shrike1201 Posted October 2, 2010 Share Posted October 2, 2010 Bump from the dead. Did they tell you what it was? Link to comment Share on other sites More sharing options...
frank_ster Posted October 2, 2010 Share Posted October 2, 2010 trany codes will clear them selves after a frew driving cycles. fyi any 5 eat car if you turn the ignition on and push the car in N the sport light will come on and set cel for p0700 ! if you use the cars obd2 reader it will tell you what part of the tranny is freaking out . Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
jton Posted October 2, 2010 Share Posted October 2, 2010 only if they can clear. after my tranny swap i was getting 4 codes. 2 went away after a few driving cycles. was getting incorrect 1st gear ratio. had to have the tcm reset and put in learning mode - drove like shit till i did this too. it would slip in 1st gear on initial accel. Link to comment Share on other sites More sharing options...
mikeslgt Posted January 22, 2011 Share Posted January 22, 2011 trany codes will clear them selves after a frew driving cycles. fyi any 5 eat car if you turn the ignition on and push the car in N the sport light will come on and set cel for p0700 ! if you use the cars obd2 reader it will tell you what part of the tranny is freaking out . was stuck on the highway, it was backed up due to an accident. Looked down the road at a long line of taillights, all down hill. so, i figure shut the car off and coast down the hill. and sure enough, as i turned the key on while coasting it triggered the CEL. that flashing cruise is annoying, why have that? i love my gt but this is a weird suby 'feature'. Link to comment Share on other sites More sharing options...
ehsnils Posted January 23, 2011 Share Posted January 23, 2011 Since you have the AT gearbox it's probably just that it was a situation that they never really tested. The gearbox control unit doesn't like strange situations and throws a CEL when it thinks that the reality is skewed. Link to comment Share on other sites More sharing options...
Doogie Posted April 9, 2011 Share Posted April 9, 2011 My turn now with the PO700 code...accessport reads - Request AT Mil On. 08 LGT 5eat..seems to have gone into limp mode..feels like it starts in 3rd gear..lots of lights-o-flashin.Had been driving for 20 plus miles after loading an OTS stg2 cobb map(yes, I have the high flow cats,stock air filter per Cobb ).Passing while in the boost on highway, and set the cel,cruise,s-drive lights off....Any suggestions are appreciated. Link to comment Share on other sites More sharing options...
ehsnils Posted April 10, 2011 Share Posted April 10, 2011 It just says that the gearbox has thrown a MIL code, so you can't tell anything about it through a regular code read. I would start with trying a code reset by disconnecting the battery and push the brake pedal for 20-30 seconds and see if the car goes back to normal. If it comes back I would step back to original map and try again. If it doesn't come back on original map but comes with the Cobb map then it's time to check in with Cobb and see what they say. And of course see what code the gearbox throws. Link to comment Share on other sites More sharing options...
Doogie Posted April 10, 2011 Share Posted April 10, 2011 Thanks! I will try that this morning. Link to comment Share on other sites More sharing options...
Doogie Posted July 9, 2011 Share Posted July 9, 2011 Resurrecting the dead. Went back to stock tune. More trans related symptoms + 3 trips to 2 dealers later, had SOA involved , and nothing accomplished. Went to my trans buddy who did a proper servicing and have had no problems whatsoever since. Why couldn't SOA, and 2 dealers just recommend a servicing ? Oh well. Thanks ! Link to comment Share on other sites More sharing options...
spyguy Posted September 25, 2018 Share Posted September 25, 2018 Can anyone recommend a automatic transmission mechanic for my 2005 lgt here in Atlanta, Georgia? I got there similar code recently. Seemingly out of the blue too. Link to comment Share on other sites More sharing options...
relative4 Posted September 25, 2018 Share Posted September 25, 2018 Link to comment Share on other sites More sharing options...
