HID Foglight Install
There was a thread on here from 2007 that went into great great great detail about installing HID's into the foglights:
http://legacygt.com/forums/showpost.php?p=1021172&postcount=73
Its a great writeup that goes into incredible detail, but its a little too busy for me (and no pictures).
I think it can be explained in a more simple fashion.
So here's mine...
If you're trying HID's in the fogs, chances are you've already mastered the HID's in the headlights. Headlights were simple.... the only thing that was altered was that gray "dust cap." Well the fogs are similar, but they have a black "dust cap" that needs a little more modification. The headlights can easily be put back to stock halogen, whereas the fogs WILL NOT be able to return to stock.
What you will be modifying:
1. the black plastic fog light dust cap with plug
2. the short OEM fog light harness with white plug and gray plug
Those two things are all you would need to return to stock, so even if you did want to go back it would be as easy as getting new dust caps and short harnesses.
Lets begin..
I removed the front bumper to get to everything easier. This makes accessing the foglights and mounting ballasts much much easier.
Take that short wire harness that was connected to the black cap and hack the gray plug off.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc1/hs118.snc1/4981_524967085312_72100768_31074995_7536372_n.jpg
http://legacygt.com/forums/attachment.php?attachmentid=135654&stc=1&thumb=1&d=1354582971
Take the black plastic dust caps and cut the plug part off of it, leaving you with a nice opening. I used a drill, pliers, and the sidewalk (as sandpaper) to do this. I'm sure you have the proper tools, i.e. a dremel. Get the opening to be about the size of the back of the cap... see pics below.
http://a1.sphotos.ak.fbcdn.net/photos-ak-snc1/v4981/231/4/72100768/n72100768_31074996_3731812.jpghttp://legacygt.com/forums/attachment.php?attachmentid=135655&stc=1&thumb=1&d=1354582971
Take the HID power wires out of the rubber grommet and cut the connectors off of it (as shown in the bottom right of the pic above)
Solder the hacked HID power wires to the short OEM harness that has the white plug (red to red, black to black)
Pull the HID wires and grommet through the hole in the black dust cap. Seal the grommet using silicone sealant or whatever. Also put some sealant in the holes in the grommet where the red and black power wires once were.
All this should yield you the following:
4981_524967095292_72100768_31074997_7118756_n.jpghttp://legacygt.com/forums/attachment.php?attachmentid=135656&stc=1&thumb=1&d=1354582971
Pretty self explanatory from here...
H3 HID bulbs go in factory fog light housing,
put on black dust cap,
connect HID to ballast to factory plug,
mount ballasts,
put bumper back on,
enjoy!
note: plugs are all different, so they will only plug into exactly where they are supposed to go!! easy!!
oh and if you mess something up, its not my fault... mine work perfectly ;)
This seems a lot more complicated than it actually is. Once you get the H3 HID kit and open the box, everything will make more sense.
Edited by absolutsnwbrdr
re-insert pictures
  • Replies 71
  • Created
  • Last Reply
Top Posters In This Topic
Everythings good to go!
http://photos-c.ak.fbcdn.net/hphotos-ak-snc1/hs098.snc1/4981_524961835832_72100768_31074722_4425212_n.jpg
Hope this walkthrough helps at least one person! If I wasnt clear enough about something, ask and I'll be happy to clarify!
the light output from the fogs alone is tremendous, but a lot of the light is wasted
because fogs arent made to project 100' in front of you (they arent driving lights). if either of the 5000k fog hids go bad, i will be keeping them hid, but probably going with 3000k. i'm happy with it for now though! looks awesome at night!
after i finished them last night, i went for a short drive but only had my cell phone on me so i couldnt get good pictures. maybe i'll take my nice digital out tonight and get some good pics that show the output from fogs only, lows only, and fogs + lows.
as halogens they dont put out a whole lot of light on the road to begin with
As fog lights, they aren't really designed to. Their intended purpose is project yellow colored light to the low and immediate road in front of the car in an effort to reduce the amount of light reflected back by the moisture in the air; which is what happens to driving, low, and high beams.
Actually I have my fog lights adjusted "upwards" and even with my HIDs (55 Watt, 4200 K - which are the whitest) I can tell the fog lights. It gives me more peripheral vision and project maybe about 5-7 meters in front of the car. It is not just a subtle difference. I have the non-HID Narva 55 watt (H3 I believe) bulbs.
I love this picture, looks like you backed over a curb and your front bumper and grill fell off! :lol:
I know that isn't the point, but it made me laugh.
+1
Every time someone says the Legacy fog lights suck, I wonder if they've checked the aim on theirs. Mine were angled way too low from the factory, and basically worthless. Now they work just as well as the fogs on my previous car (91 BMW 325ix).
would like to see pics of a lower temp bulb. Like a 3000k
http://img.photobucket.com/albums/v326/StevenCole/Auto%20Photo%20Shoots/Legacy/DSC_8203.jpg
http://img.photobucket.com/albums/v326/StevenCole/Auto%20Photo%20Shoots/Legacy/DSC_8291.jpg
276hp/347tq On a DynoJet
Dyno Video - Had a big lean spot as you can tell in the second pull
sorry about the delay... here are the pics... dont really do the lights justice. I think I'm going to have to find a better spot that demonstrates how far the light actually goes....
Only Fogs:
http://photos-h.ak.fbcdn.net/hphotos-ak-snc1/hs109.snc1/4922_525077369302_72100768_31080367_3628371_n.jpghttp://legacygt.com/forums/attachment.php?attachmentid=135658&stc=1&thumb=1&d=1354583194
Only Lowbeams:
http://photos-a.ak.fbcdn.net/hphotos-ak-snc1/hs089.snc1/4922_525077374292_72100768_31080368_1752588_n.jpghttp://legacygt.com/forums/attachment.php?attachmentid=135659&stc=1&thumb=1&d=1354583194
Lowbeams & Fogs:
http://legacygt.com/forums/attachment.php?attachmentid=135660&stc=1&thumb=1&d=1354583194
http://photos-g.ak.fbcdn.net/hphotos-ak-snc1/hs109.snc1/4922_525077364312_72100768_31080366_6101663_n.jpg
fix pictures
Sorry my write-up was to detailed and tedious :lol:
I have noticed better performance in inclement weather w/ my 2300K HID fogs, than I had before w/ PIAA Ion Crystals...
But, that is using them as fogs, not driving lights ;)
:spin:
