G mang T Posted September 16, 2008 Share Posted September 16, 2008 i figure the biggest spacer i could use is 15mm to create that wider aggressive look and give her a little bump in handling..any experience with these out there? tips? im stuck on this one Link to comment Share on other sites More sharing options...
SBT Posted September 16, 2008 Share Posted September 16, 2008 You want to move your tires further from your springs? Not sure what the advantage you're trying to achieve here. You don't mention whether you're running an ultra-wide rim/tire combination (would presume, otherwise, why move the wheel outward). You do realize that as you move your wheel outward, that you're also increasing the loading on your wheel bearings and changing the steering geometry. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
JonLGT Posted September 16, 2008 Share Posted September 16, 2008 With 15MM spacers you will also need to replace studs also. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted September 16, 2008 Share Posted September 16, 2008 ^+1 a wheeloff would not be funn Link to comment Share on other sites More sharing options...
G mang T Posted September 30, 2008 Author Share Posted September 30, 2008 i will post some pictures but everything worked great! just had to roll the fenders a few mm and she looks like a champ! Link to comment Share on other sites More sharing options...
jamal Posted October 1, 2008 Share Posted October 1, 2008 so how many turns of thread did you get out of the lug nuts? Just so you know, wheel spacers and s-techs are pretty much the exact opposite of what you should do to make a car handle well. At least you'll be hella flush approved? Link to comment Share on other sites More sharing options...
G mang T Posted October 2, 2008 Author Share Posted October 2, 2008 huh^ bought the bolt on ones brotha. dont care much. if i want to go track it in the future ill take off the spacers and im ready to roll. i just think the legacy doesnt look muscular enough with stock rims and stock ride height. i wish subaru widened it a bit and slapped on some rear fender flares yadida mean? Link to comment Share on other sites More sharing options...
DiscoWagon Posted October 2, 2008 Share Posted October 2, 2008 Did you at least get an alignment? Link to comment Share on other sites More sharing options...
G mang T Posted October 2, 2008 Author Share Posted October 2, 2008 of course Link to comment Share on other sites More sharing options...
