05SilverScubie Posted June 1, 2012 Share Posted June 1, 2012 I have an 07 Spec B and when it starts to get hot out (usually 80 or above) and the interior is warm as well, my factory head unit will completely lock up to the point I cannot control the volume or change channels and the only thing I can do is turn it off. Also when this happens, if i press a different preset button (ie change from 2 to 5), it won't do anything, then after a few seconds, will store that channel to another preset. I've noticed the screen flicker here and there. Usually a good fix (and I hate to admit this because it's not nice to hit a lady) is to give a good thump to the side of the radio console, screen blinks, and all is back to normal. When it get really hot out, this is just a continuous process. This doesn't happen when it's cold, only hot. Any advice or suggestions????? Link to comment Share on other sites More sharing options...
ssbtech Posted June 1, 2012 Share Posted June 1, 2012 I don't know. Not sure if it's temperature related either. My 05 head unit did it from time to time, the 07 head unit I put in there also does it from time to time. When it does it, I can turn the radio on and off, but not change volume, channels or input. The radio screen is blank. The climate control does let me change fan speed, aire direction and I think the temperature, but that screen is blank too. Turning the car off and on again seems to fix everything. Link to comment Share on other sites More sharing options...
theflystyle Posted June 2, 2012 Share Posted June 2, 2012 i think this is an issue others have encountered (such as myself). exact same symptoms as ssbtech Link to comment Share on other sites More sharing options...
05SilverScubie Posted June 2, 2012 Author Share Posted June 2, 2012 Hmm.....I'm guessing any dealer will get out of trying to fix this. I wonder if enough have the issue if SOA will help out somehow. They did when my windshield cracked on both my 05 and 07 from the defrosters. Link to comment Share on other sites More sharing options...
Heedz Posted June 3, 2012 Share Posted June 3, 2012 my stocker did that forsure. overheating somewhere. Link to comment Share on other sites More sharing options...
ssbtech Posted June 3, 2012 Share Posted June 3, 2012 I don't think this is an overheating issue, mine has done it when cold out too. Link to comment Share on other sites More sharing options...
rouar Posted June 4, 2012 Share Posted June 4, 2012 http://legacygt.com/forums/showthread.php/radio-display-fix-142191.html Link to comment Share on other sites More sharing options...
05SilverScubie Posted June 6, 2012 Author Share Posted June 6, 2012 Thought I searched hard enough to see if anyone had posted about this....guess I was wrong... Thanks! Link to comment Share on other sites More sharing options...
ThatVAguy Posted June 8, 2012 Share Posted June 8, 2012 Regularly recurring problem with the 4th gen stereo/climate control boards made by Toshiba. SOA knows of it, but according to my dealership in order to replace it you have to be the original owner of the vehicle. So i'm saying screw it and looking at getting a double din Link to comment Share on other sites More sharing options...
05SilverScubie Posted June 8, 2012 Author Share Posted June 8, 2012 Don't even get me started on dealerships.....but SOA does take care of us IMO Link to comment Share on other sites More sharing options...
heleu Posted June 13, 2012 Share Posted June 13, 2012 This has happened about 10 times on my 07 Spec B with a 100K miles. Thanks for posting this, I'll try to "push" the radio and see what happens. Link to comment Share on other sites More sharing options...
rouar Posted June 18, 2012 Share Posted June 18, 2012 Pushing on the face between the Balance and Audio buttons does the trick for me. Link to comment Share on other sites More sharing options...
Utmost Posted June 18, 2012 Share Posted June 18, 2012 My 06 spec has done the same thing, also had problems with the steering wheel audio controls too. Dunno what "fixes" it, other than my random pushing and shed tears of worry. Link to comment Share on other sites More sharing options...
heleu Posted June 18, 2012 Share Posted June 18, 2012 Pushing on the face between the Balance and Audio buttons does the trick for me. Yeah, it works for me as well. I'm far too lazy to take apart the radio and look for a loose connection... Link to comment Share on other sites More sharing options...
