Zac88 Posted August 6, 2010 Share Posted August 6, 2010 looking for the diagnostic connectors so I can read a CEL from my 2005 LGT. Link to comment Share on other sites More sharing options...
outahere Posted August 6, 2010 Share Posted August 6, 2010 Near the driver's left leg, under the dash Link to comment Share on other sites More sharing options...
Scotty Posted August 7, 2010 Share Posted August 7, 2010 Pop the fuse cover, and dig in deep. It's very well hidden and very well taped to the other harness. Link to comment Share on other sites More sharing options...
nyc97obw Posted August 7, 2010 Share Posted August 7, 2010 There is no need to pop the fuse cover, it is just behind the fuses cover and easily reached. BTW, very odd that the OBD interface location is nowhere mentioned in the owners manual. Took me awhile to find it. Link to comment Share on other sites More sharing options...
zmarko Posted August 7, 2010 Share Posted August 7, 2010 Just look under the dash in the drivers footwell, can't miss it. Link to comment Share on other sites More sharing options...
Zac88 Posted August 7, 2010 Author Share Posted August 7, 2010 ok after I connect them how do I check for codes? Link to comment Share on other sites More sharing options...
devobuzz Posted August 7, 2010 Share Posted August 7, 2010 There is a green and white male plug and white female plug up there. Connect the two white female plugs and as the guages sweep, press the trip reset button. The code is in fact displayed on the odometer. Link to comment Share on other sites More sharing options...
tzdevil323 Posted August 8, 2010 Share Posted August 8, 2010 OK after I connect them how do I check for codes? connect them? if your referring to the the two green plugs in the front passenger foot well those are for putting the car in test mode for reading and writing to the cars ECU for ROM updates and tuning. OBDII plug is on the left side the driver foot well and an OBDII scanner would be needed. I'm hungry:bbq:This burger is never gonna cook. Link to comment Share on other sites More sharing options...
moncur_6 Posted August 8, 2010 Share Posted August 8, 2010 If you want to check a code, there is a series of buttons to push in the car to check the code w/o a scanner I think this is it... Turn key to accessory Before the needles do a full sweep, turn parking lights on (1 click on lights) click trip button 3 times parking lights off trip button 3 times parking lights on trip 3 times I think you just do it three...then the code shows up on the odometer. Search it in this site and you'll find the post of all CEL codes Link to comment Share on other sites More sharing options...
shutterbc Posted August 8, 2010 Share Posted August 8, 2010 ^ that sounds more like a cheat code for a Nintendo than a diagnostic procedure. I bought a cheap code reader, but your method sounds more entertaining! Link to comment Share on other sites More sharing options...
moncur_6 Posted August 8, 2010 Share Posted August 8, 2010 ha ha yeah I didn't believe it worked and then...voila! I still play my N64...often. My wii has old nintendo and sega games on it too ohh the 90's Link to comment Share on other sites More sharing options...
