Vaders_3.0R Posted August 14, 2014 Share Posted August 14, 2014 Hey all I have an 09 leggy with a little over 65k on it. SoCal car its whole life. I have A Whiteline setup under the car with endlinks and sway bars. The noise happens when I hit a bump or pothole etc. Basically whenever the pass rear tire moves. I have the clamps on the bars to prevent movement laterally. The endlinks are tight to spec. Anyone encounter this issue? Control arm bushing bad? Maybe something with shock/spring? Its not a hard cluck more like a click noise which is what has me stumped. Thanks all! Link to comment Share on other sites More sharing options...
PhillyWilly Posted August 14, 2014 Share Posted August 14, 2014 Stock endlinks? My clunks from bumps mostly went away with upgraded endlinks. Link to comment Share on other sites More sharing options...
Vaders_3.0R Posted August 14, 2014 Author Share Posted August 14, 2014 Stock endlinks? My clunks from bumps mostly went away with upgraded endlinks. No they are the Whiteline adjustable ones. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted August 14, 2014 Share Posted August 14, 2014 My clunking issue was due to having to replace my bushings. I have a Perrin 22 mm rear sway with AVO reinforcement brackets. My clunking was on the passenger side. This was after about 6 years. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
ruthlessromeo Posted September 2, 2014 Share Posted September 2, 2014 replaced my links and top hats, still have the clunking.. maybe bushings are next Link to comment Share on other sites More sharing options...
orndog Posted September 2, 2014 Share Posted September 2, 2014 Try putting a dab of grease on the sway bar bushings. Link to comment Share on other sites More sharing options...
