Protuning Lab exhaust $318.
Max Capacity
http://www.protuninglab.com/cbe-legacy-t2-ss.html?utm_source=googlepepla&utm_medium=adwords&id=86425746746
Has any one got this ? How's it sound ?
Is that to good to be true ?
Engine Build - Click Here
I did hear back from them. They don't have a sound clip only the picture.
I asked a few more questions, about fit up.
He did reply in a timely fashion.
Thanks for the link. I like to at least deal with a shop/place that I can email and get some customer service from.
  • 2 weeks later...
Had no real issue with customer service. They have answered my emails in a timely fashion.
The exhaust is load, it's hard to talk when driving.
I'll try the stock mufflers if it's not raining when I get home tonight.
If that's not a good fit then the magnaflow 14319 seems like an option that seems to work.
Another option is a 5" Borla xr-1 muffler. I had one welded in place of a 4" resonator on my AutoSpeed midpipe. It cut the volume way down.
"Striving to better, oft we mar what's well." - Bill Shakespeare - car modder
Max have you heard the Magnaflow 14319 in person.
Looking for a little sound but not to loud
No I have not, just in the video in the wagon exhaust thread. I don't think that lowered the volume enough.
http://legacygt.com/forums/showthread.php/wagon-folks-resonator-helpi-87917.html
post 62
The other issue is the inside hanger rod is about a inch shorter then it needs to be. I used a screw type hose clamp on the outside rubber hanger to pull the muffler tip to the outside.
I put the stock mufflers back on with only a washer between the flanges on the top flange bolt. It's a little louder then stock but better to ride in the car and talk to someone.
Next big change will be when the Grimmspeed TMIC get's put on and a smaller boost pill with a tune.
Hawgzuast? Hows the rust on your stock flanges? I have been wanting to do that. Just want a tiny bit more noise, but all sorts of rust on that part of the exhaust.
Ditto, lots of rust. Just pick up four 8mm x1.25 bolts, about 1.5" long and nuts with washers and lock washers, can of PB Blaster, and anti seize compound and do it.
