giotein Posted December 15, 2005 Share Posted December 15, 2005 i have been reading on past topics on Tein Basic vs Tein Flex. I dont think this question came up because i had no luck finding anything on it. With the softest settings on Tein Flex, will it ever be as soft OR softer than the Basic?? Link to comment Share on other sites More sharing options...
Xenonk Posted December 15, 2005 Share Posted December 15, 2005 what you are comparing to are the shocks, not the springs.. you are comparing apples to oranges.. Keefe Link to comment Share on other sites More sharing options...
giotein Posted December 15, 2005 Author Share Posted December 15, 2005 arent they both coilovers??? just that Flex you can adjust the stiffness.... Link to comment Share on other sites More sharing options...
Xenonk Posted December 15, 2005 Share Posted December 15, 2005 the basics are basically a stock design with a lower spring perch and shorter spring.. just think of it that way (and if you had to isolate the two with having equal spring rates, the Basics are just enough to handle the shorten ride height, like a stock shock/spring setup was designed as well.. hopefully, a near stock ride feel but with a lower stance).. compare the two spring rates for each.. that should give you an idication of how aggressive the shock valving is.. but from my knowledge, Tein's have been on the softer side of things for the "street" use version.. even the Flex is soft to me and it's pretty sensitive to ride height and shock travel changes (so do read the manual to know what the lowering limits are for the FLEX). The only Teins that I do give praise to are the racing ones (seems that those are the ones that get the most R&D and Tein designed them right.. too bad they don't spend as much time with the rest of their lineup of suspension parts. Keefe Link to comment Share on other sites More sharing options...
NatesGr8 Posted December 15, 2005 Share Posted December 15, 2005 The only Teins that I do give praise to are the racing ones (seems that those are the ones that get the most R&D and Tein designed them right.. too bad they don't spend as much time with the rest of their lineup of suspension parts. +1 but that little Tein guy is sooo cool Link to comment Share on other sites More sharing options...
