carguyco Posted April 28, 2012 Share Posted April 28, 2012 Had my oil changed at dealership.. Tech notated that my shift shaft seal was leaking...$350 I declined until I researched it.... I searched here..found nothing......anyone? Thanks Link to comment Share on other sites More sharing options...
mitskip Posted October 2, 2013 Share Posted October 2, 2013 Just had the same thing from the dealer after the brake recall. Info on this?? Link to comment Share on other sites More sharing options...
GTTuner Posted October 2, 2013 Share Posted October 2, 2013 Everyone I ever saw leaks somewhat, is it dripping on the ground? Mine has leaked/had seepage for over 100k, if it ain't dripping on the ground leave it alone. Link to comment Share on other sites More sharing options...
mitskip Posted October 2, 2013 Share Posted October 2, 2013 No drips on the ground. Is it something that can be easily replaced when doing a clutch job? edit: Just talked to the tech, sounds like they are just covering their butts. I'm planning on doing the diffs/manual trans fluid change when I do the clutch swap, and I'll pick up that seal while I have everything unhooked I assume it will be fairly easy to get it in there. Link to comment Share on other sites More sharing options...
GTTuner Posted October 5, 2013 Share Posted October 5, 2013 You can actually change it with the trans still in the car. Change your center diff "driven gear" bearings while your in there. Link to comment Share on other sites More sharing options...
