snow05gtRI Posted August 6, 2014 Share Posted August 6, 2014 I want to start doing some of my own maintenance. however, I'm lowered and also have a JDM front end. looking at race-ramps I need the ones that they claim need a 7.25" clearance on their angle test (use a yard stick under front wheel and raise it, see how high it gets off ground before hitting underside). if not ramps, I need to find a jack that will fit, and some jack-stands. i know this is opinion based, but what do you all feel about ramps vs. jacks? any pros/cons to either? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2014 Share Posted August 6, 2014 Go to home depot, pick up some 2x8's. make your own, cut two about 4ft long, bevel one edge. cut another two about 3ft long, bevel one edge, attach them on top of the 4ft ones. cut two pieces 2ft long....get the idea. Harbor Fright has some nice floor jacks and jack stands too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted August 6, 2014 Share Posted August 6, 2014 I don't have the room for ramps, so I have a low profile jack. Got this one from Harbor Freight, works good and won't break the bank. Sometimes you can get 20% off if you watch their specials. http://www.harborfreight.com/3-ton-low-profile-steel-heavy-duty-floor-jack-with-rapid-pump-61253.html My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2014 Share Posted August 6, 2014 You only have one floor jack...? young guy's... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted August 6, 2014 Share Posted August 6, 2014 Had two, until one bled to death. Don't have the need for 2 anymore. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
theflystyle Posted August 7, 2014 Share Posted August 7, 2014 Ive been using this guy ([ame=http://www.amazon.com/gp/product/B00132CGEW/ref=wms_ohs_product?ie=UTF8&psc=1]LINKY[/ame]) on my lowered car for years and love it. Its slightly higher than the HF one but was way lighter. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2014 Share Posted August 7, 2014 Anybody try these yet ? http://www.northerntool.com/shop/tools/product_200631798_200631798?url?utm_source=Email&utm_medium=New_080714&utm_campaign=eDeals_080714&utm_content=P4&cm_lm=byron.smith@hs.utc.com&STATE=CT&HOT_MEM_CODE=&MARKETCODE=&om_rid=AAEo2i&om_mid=_BT43h-B87pZPsX Could be a nice gift from Santa Claus. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
evildriver Posted August 7, 2014 Share Posted August 7, 2014 i have a "low" profile jack from HF and still need to drive up on some wood ramps i made to be able to jack up the front, and i'm only lowered on STi pinks. Link to comment Share on other sites More sharing options...
kirshnerd Posted August 7, 2014 Share Posted August 7, 2014 I'm lowered on coils with a lip, and was the same on my previous car. One low profile HF jack and 2 pieces of wood is all I've ever needed to get anything done. Drive onto two foot long pieces of 2x8 with the front wheels. Jack under front, lift, onto jackstands. Jack under rear, lift, onto jackstands. Done. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 7, 2014 Share Posted August 7, 2014 Anybody try these yet ? http://www.northerntool.com/shop/tools/product_200631798_200631798?url?utm_source=Email&utm_medium=New_080714&utm_campaign=eDeals_080714&utm_content=P4&cm_lm=byron.smith@hs.utc.com&STATE=CT&HOT_MEM_CODE=&MARKETCODE=&om_rid=AAEo2i&om_mid=_BT43h-B87pZPsX Could be a nice gift from Santa Claus. My buddy uses those on his dirt late model. They do a great job of lifting and he made an "X" piece that ties them together so they stay in perfect position so he just drives over them and lines up one spot and the other 3 are all set. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 7, 2014 Share Posted August 7, 2014 You only have one floor jack...? young guy's... One floor jack gets you into trouble and two gets you back out Link to comment Share on other sites More sharing options...
chato Posted August 7, 2014 Share Posted August 7, 2014 I can get this one under the car no problem. The suspension is set at about a finger width between tire and the wheel well arch. oh, and check out Rhinoramps, I can get on those with the help of a 1x6 or two. Link to comment Share on other sites More sharing options...
Waaazooo Posted August 8, 2014 Share Posted August 8, 2014 I just use link levers for rv's. Walmart buy and they are storable. Link to comment Share on other sites More sharing options...
kirshnerd Posted August 8, 2014 Share Posted August 8, 2014 Theres a good price on the Harbor Freight low profile jack currently... http://www.harborfreight.com/3-ton-Low-Profile-Steel-Heavy-Duty-Floor-Jack-with-Rapid-Pump-61253.html?ccdenc=eyJjb2RlIjoiNjUyOTcwMDIiLCJza3UiOiI2MTI1MyIsImlzIjoiODQuOTkiLCJwcm9kdWN0X2lk%0D%0AIjoiOTk0OCJ9%0D%0A Not aluminium but 1/2 the price. Link to comment Share on other sites More sharing options...
Holla Posted August 8, 2014 Share Posted August 8, 2014 If I needed to choose between the two, I'd get a jack WITH jack stands. Ramps can be convenient but you can get more done with the jack. It's going to be near impossible to get the wheels off your car with just ramps. Link to comment Share on other sites More sharing options...
boxman Posted August 8, 2014 Share Posted August 8, 2014 If I needed to choose between the two, I'd get a jack WITH jack stands. Ramps can be convenient but you can get more done with the jack. It's going to be near impossible to get the wheels off your car with just ramps. The answer is "Both". You need 2 jacks, 4 jack stands and a set of low profile ramps...or, in a perfect world, a lift... Link to comment Share on other sites More sharing options...
chato Posted August 8, 2014 Share Posted August 8, 2014 I got that HF aluminum one for $80. Just gotta wait for the sale cycle to come around. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 8, 2014 Share Posted August 8, 2014 One floor jack gets you into trouble and two gets you back out Exactly. A third one comes in handy when the tranny jack, just can't get the right angle. My third one is the small $30 trolley jack. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Holla Posted August 8, 2014 Share Posted August 8, 2014 The answer is "Both". You need 2 jacks, 4 jack stands and a set of low profile ramps...or, in a perfect world, a lift... I agree, but if you currently have nothing and don't want to drop $500 to do simple maintenance like a brake job or something, you can easily get by with a jack and two stands. If you're planning on dropping the transmission in your driveway, then that's a different story. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted August 8, 2014 Share Posted August 8, 2014 I'm going to be looking for a new floor jack soon. That one linked here from HF is the one I had my eye on recently. I'll have two floor jacks, two jack stands and ramps if I grab a new floor jack. Enough to pull a trans in my driveway, yay!! EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
boxman Posted August 9, 2014 Share Posted August 9, 2014 I wasn't even counting a transmission jack. Link to comment Share on other sites More sharing options...
apexi Posted August 9, 2014 Share Posted August 9, 2014 Those race ramps look friggin expensive.. Back when I had a lowered car I was able to get by with these yellow ramps with the black ramp extenders for low profile cars. I agree with others that said both, but If I had to pick between the two, I would probably go with a low profile jack and two jack stands. Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 12, 2014 Author Share Posted August 12, 2014 thanks for the thoughts. looking at the jacks suggested and also seeing what else I can find. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 12, 2014 Share Posted August 12, 2014 I'm going to be looking for a new floor jack soon. That one linked here from HF is the one I had my eye on recently. I'll have two floor jacks, two jack stands and ramps if I grab a new floor jack. Enough to pull a trans in my driveway, yay!! Spend the extra $$$ and get the low tranny jack from HF. I have the $60 one and it needs 7 or 8 inches by it's self. I have four 24" jack stands so I was able to get the car high enough to roll the tranny under car between the LCA and the oil filter area. IMO a floor jack is not a good tranny jack, I also use a tie down strap in place of the strap that came with the tranny jack. Do you have blocks of 4x4's(on the floor jacks) to get the car up real high ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted August 12, 2014 Share Posted August 12, 2014 The answer is "Both". You need 2 jacks, 4 jack stands and a set of low profile ramps...or, in a perfect world, a lift... Just saying, if your young and plan to work on your cars...those $900 lifts will pay for themselfs over time. I'm almost 60y/o, those things would have been great to have over the past 40+ years. My engine hoist has more than paid for itself. It was $199 back about 14 years ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
