boostedsubbygt Posted July 20, 2014 Share Posted July 20, 2014 So this is the second oil change that my car can't make it to without a quart or 2 addin before the shop. Is this strange to LGT or the norm. I have about 108645 miles on it and live in the washington dc area so traffic is a beast especially with a 5 speed. Any advice or warning to look out for. Oh yea it's a 2006 Link to comment Share on other sites More sharing options...
MrTris Posted July 20, 2014 Share Posted July 20, 2014 What's a "subby"? Is that like, a BDSM thing? Link to comment Share on other sites More sharing options...
firehawk618 Posted July 20, 2014 Share Posted July 20, 2014 My car has 110k miles. I go through 1/2 a quart at the MOST between oil changes. I have been going 4,500 miles between changes. I am NOT nice to my car either. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
MrTris Posted July 20, 2014 Share Posted July 20, 2014 My car has 110k miles. I go through 1/2 a quart at the MOST between oil changes. I have been going 4,500 miles between changes. I am NOT nice to my car either. Yeah, we heard! OP, you've probably got ringland damage, judging by your excessive oil consumption. Is there a lot of smoke? Link to comment Share on other sites More sharing options...
Gex Posted July 20, 2014 Share Posted July 20, 2014 Or a blown turbo... Or a badly clogged pcv(reaching here). With no further info and e-diagnostic. Drop down pipe check turbo,check half moon seals oil lines etc..., if good compression and leak down test. 1-2 quarts is not normal. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 20, 2014 Author Share Posted July 20, 2014 No smoke at all but it still gets boost fine. Would it still be able to do that with a blown turbo. I hate going to the dealer but looks like I don't have a choice to save my car. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 20, 2014 Author Share Posted July 20, 2014 What's a "subby"? Is that like, a BDSM thing? I'm not sure what I was thinking Link to comment Share on other sites More sharing options...
Gex Posted July 20, 2014 Share Posted July 20, 2014 Avoid the dealer find a good local shop. Please. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2014 Share Posted July 20, 2014 No smoke at all but it still gets boost fine. Would it still be able to do that with a blown turbo. I hate going to the dealer but looks like I don't have a choice to save my car. If the engine runs fine, keep the oil topped off, keep driving it. Start saving your money. Have a plan in place to replace the engine if/when it comes time. The turbos last about 120,000 miles. It's a good idea to plan on replacing it sometime around then. Read the click here link in my sig. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
c-lo Posted July 20, 2014 Share Posted July 20, 2014 synthetic or regular? Mine burns thru synthetic, so I use high mileage blend instead. sometimes I have to add 1/2-1 quart/every 3k....sometimes I dont 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
lingling1337 Posted July 20, 2014 Share Posted July 20, 2014 Does the high mileage work wonders c-lo? I'm killing 1q every 1k miles with perfect compression, turbo, pcv, lines, etc. on 5w40. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 20, 2014 Author Share Posted July 20, 2014 synthetic or regular? Mine burns thru synthetic, so I use high mileage blend instead. sometimes I have to add 1/2-1 quart/every 3k....sometimes I dont All synthetic Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 20, 2014 Author Share Posted July 20, 2014 Avoid the dealer find a good local shop. Please. Ok I'll start searching this area has alot of competition so just gotta be frugal Link to comment Share on other sites More sharing options...
lee07 Posted July 20, 2014 Share Posted July 20, 2014 Normal, unless you're adding 4 quarts between oil changes, then you got issues, but 1-2 is normal. I add about 1 1/2 between changes. Just drive it and check it every 1000 miles Link to comment Share on other sites More sharing options...
Redryan98 Posted July 20, 2014 Share Posted July 20, 2014 What kind of oil are you using? Try rotella t6 if you're not using it already. If you have "normal" consumption it might help a little. If it's being caused by something that is want or broken you'll have to investigate further. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 20, 2014 Author Share Posted July 20, 2014 What kind of oil are you using? Try rotella t6 if you're not using it already. If you have "normal" consumption it might help a little. If it's being caused by something that is want or broken you'll have to investigate further. Subaru oil at dealer Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 20, 2014 Author Share Posted July 20, 2014 Isn't t6 5w40 only. Been using suabru 50 lately wouldn't that harm the car switching weights? Link to comment Share on other sites More sharing options...
c-lo Posted July 20, 2014 Share Posted July 20, 2014 Does the high mileage work wonders c-lo? I'm killing 1q every 1k miles with perfect compression, turbo, pcv, lines, etc. on 5w40. Castrol 10w40 high mileage. with 261k on my car....yes I think so. synthetic runs through my car like water. I dare not go back. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
boostedsubbygt Posted July 24, 2014 Author Share Posted July 24, 2014 Got some Castrol high milage and so far so good. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted August 11, 2014 Author Share Posted August 11, 2014 So subaru says it's a valve cover leak that could be my problem with the oil consimtion. Whew and wants to charge 825 to fix. It's 500 to order a new car I wonder if I should pop smoke and go for a new ride. The new legacy looks ok or the rare to find wrx Link to comment Share on other sites More sharing options...
c-lo Posted August 12, 2014 Share Posted August 12, 2014 since you switched are you still having oil consumption issues? how bad is it now? do I trust dealers? no. if it were me would I get a second opinion from a subie specialist that doesn't work at a dealership? yes 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
boostedsubbygt Posted August 12, 2014 Author Share Posted August 12, 2014 No problem since switched oil. I was due for a oil change and they told me at subaru what they found. They put in subaru oil so I'll have to check it till it runs low then I'll put more high milage again. Link to comment Share on other sites More sharing options...
boostedsubbygt Posted August 12, 2014 Author Share Posted August 12, 2014 I agree with the dealership. Plus 1125 for front struts leaking it's insane along with the 825 valve cover. Somethings strange Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 12, 2014 Moderators Share Posted August 12, 2014 You're in the DC area? Where, exactly? I'm down in Springfield. Oil consumption could certainly be a VCG, but with your mileage I would also suspect PCV or turbo seals as well. As others mentioned could also be ringland issues. Lots of folks in the area that do work on the side, just FYI! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boostedsubbygt Posted August 12, 2014 Author Share Posted August 12, 2014 Ya I'm in the DC area close to Annapolis. Hey if you could point me in the right direction it would help. I just moved here and the dealer has been my only mechanic. Link to comment Share on other sites More sharing options...
