guest user Posted February 4, 2010 Share Posted February 4, 2010 Hi, I have just bought a 96 Outback with a bad radio. The radio isn't the factory model, but I'd like to replace it with a newer model factory radio. Anyone know what newer factory radios will work and fit into this car without making any modifications to the wires or the dash panel? Thanks for any help. Link to comment Share on other sites More sharing options...
Darkness of Death Posted February 4, 2010 Share Posted February 4, 2010 is your radio space a single din or double? if it's double, i think some of the new wrx radios will work. Link to comment Share on other sites More sharing options...
guest user Posted February 4, 2010 Author Share Posted February 4, 2010 Thanks for the reply.The opening is a double. I have another question.This car has a factory CD controller mounted under the radio. The changer is still under the passenger seat,whether it works or not is in question. From what I can tell,the factory radio must have had 2 plugs on the back, one for the controller and one for the changer.Can anyone confirm this? And if this is a factory setup,was it worth a darn? Would it be worth trying to restore the system, or is it better to upgrade? Thanks again. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted February 4, 2010 Share Posted February 4, 2010 Just upgrade it. I'd throw a single DIN with MP3 capabilities in there and a pocket underneath. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted February 4, 2010 Share Posted February 4, 2010 any WRX radio up to '07 can fit there and might control a factory cd changer.http://forums.nasioc.com/forums/showthread.php?t=749402 Theres a pin out on the abck of the OE radios for the '07+ radios its for the aux in. old ones for the sub out, and some for the cd changer. Link to comment Share on other sites More sharing options...
guest user Posted February 4, 2010 Author Share Posted February 4, 2010 Thanks, I think I'll need to do a little research on this. The radio that's in the car now does seem to have some control over the changer. I can hear the changer looking for a CD. Does anyone know how many ohms the factory speakers should have at the radio end of the harness? I'm showing 16 ohms,this seems high to me. Seeing as to how the radio has power,but no sound at all, my thought is the speakers had to many ohms and blew the amp in the radio. Could this happen? Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted February 5, 2010 Share Posted February 5, 2010 It should be 4 each.. 4X4=16. Link to comment Share on other sites More sharing options...
guest user Posted February 5, 2010 Author Share Posted February 5, 2010 It should be 4 each.. 4X4=16. I guess,but could all the speakers connect to the same pin? Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted February 5, 2010 Share Posted February 5, 2010 Oohh well it should still be 4 ohms. Link to comment Share on other sites More sharing options...
