Skiman Posted September 11, 2014 Share Posted September 11, 2014 Howdy all. Finally, yes, finally considering an uppipe replacement. Looking at the Invidia unit. Seems a lot of you have gone to this unit with success. Have there been any tuning, CEL, or any other issues that any have experienced? Good or bad, what have your experiences been? Link to comment Share on other sites More sharing options...
doobaruGT Posted September 11, 2014 Share Posted September 11, 2014 My invidia solid catless up was good from 08-1 month ago when the weld at the header broke. The unit I had kept the EGT sensor but if you delete that you'll need a 2.2 ohm resistir for the harness. ($2 for a pack of 5 at radio shack) It's not a perfect fit (hence the weld stress fracture) and the install is going to require patience. Overall it's an okay piece but I have since gone with the Grimmspeed unit with the flex to eliminate some of that stress. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
compsurge Posted September 11, 2014 Share Posted September 11, 2014 You can get one from an STi or an 07+ LGT and you won't have to worry about fitment issues. It's also cheaper. There are tests that show units like the Grimmspeed have a better/earlier spool gain, however. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 11, 2014 Share Posted September 11, 2014 Mine has been in there since Aug 2011, 54,000+ miles works great no fittment issues. Some say the flex joints will/can leak over time. If you suppect the welds have it checked before you put it on. I have the EGT port plugged. The pipe has been great for my needs, the wagon is my DD. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
compsurge Posted September 11, 2014 Share Posted September 11, 2014 I should have also said I've had my Invidia uppipe on for about 4 years. I have the EGT plugged in. Link to comment Share on other sites More sharing options...
ttnio Posted September 12, 2014 Share Posted September 12, 2014 From what I have gathered the STI catless uppipe is a good unit for going catless and oem look... Link to comment Share on other sites More sharing options...
Brickle Posted September 12, 2014 Share Posted September 12, 2014 Mine has been in there since Aug 2011, 54,000+ miles works great no fittment issues. Some say the flex joints will/can leak over time. If you suppect the welds have it checked before you put it on. I have the EGT port plugged. The pipe has been great for my needs, the wagon is my DD. What did you plug your EGT bung with? Looking to plug mine in my cobb, but not sure what to use. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 12, 2014 Share Posted September 12, 2014 Take the pipe to the auto parts store or Home Depot and find a bolt that will fit. It's a fairly common bolt. You may have to cut the bolt shorter but it will work. http://i185.photobucket.com/albums/x40/92Si/DSCN4752.jpg I also bolt the turbo to the up pipe. Are you replacing the oil return hose too ? they can crack from age. http://i185.photobucket.com/albums/x40/92Si/DSCN4783.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Brickle Posted September 12, 2014 Share Posted September 12, 2014 Will do. I was trying to avoid having to remove it and take it to the store, because I'm lazy, but I think that's what I'll need to do. Thanks! Link to comment Share on other sites More sharing options...
Skiman Posted September 12, 2014 Author Share Posted September 12, 2014 Thanks all. Anybody have a part number for the 2007 Uppipe? I then imagine that there is no bung and the resister option comes into play. Link to comment Share on other sites More sharing options...
ZeeMalkMan Posted September 12, 2014 Share Posted September 12, 2014 I can confrim invidia egt bung size is m12x1.5, not sure about cobb but i would think its the same. Link to comment Share on other sites More sharing options...
compsurge Posted September 12, 2014 Share Posted September 12, 2014 I can confrim invidia egt bung size is m12x1.5, not sure about cobb but i would think its the same. Of course you can confirm! They are all the same EGT sensor and have the same diameter and thread pitch. Link to comment Share on other sites More sharing options...
ZeeMalkMan Posted September 12, 2014 Share Posted September 12, 2014 Will do. I was trying to avoid having to remove it and take it to the store, because I'm lazy, but I think that's what I'll need to do. Thanks! Of course you can confirm! They are all the same EGT sensor and have the same diameter and thread pitch. Just trying to help prevent brickle from having to remove his up pipe and taking it to a store. Link to comment Share on other sites More sharing options...
compsurge Posted September 12, 2014 Share Posted September 12, 2014 They can also just take the sensor Link to comment Share on other sites More sharing options...
TheMonaLisa Posted September 12, 2014 Share Posted September 12, 2014 Get the Grimmspeed unit. Highest quality aftermarket up pipe readily available. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
