Subtleamuzement Posted April 16, 2012 Share Posted April 16, 2012 If this is a double post I apologize, no time to search the forum today and the sube is acting up. I just got the head gasket and water pump replaced a few weeks ago and now the car stalls when in first gear sometimes and my girl just called me saying it was "bucking" on the freeway so she safely parked it and had a friend drive her to work. 1. The alternator needs to be replaced as the bearing is gone, which I am tracking one down right now. 2. The ignition coil is bad on one of the nobs. I am also trying to track one of these down...probably pick and pull.... Just checking to see if the symptoms fit the path of thinking I am on.... thanks in advance.... Link to comment Share on other sites More sharing options...
gergeek Posted April 20, 2012 Share Posted April 20, 2012 Water in the fuel tank? Lack of fuel to the engine, that is what mine does when i run out of gas. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted April 23, 2012 I Donated Share Posted April 23, 2012 Well if your coil pack is bad.....start by replacing that. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Subtleamuzement Posted April 23, 2012 Author Share Posted April 23, 2012 The bucking was from the timing belt. It was 2 teeth off so when the car went above 3500rmp it would start to act up. That was fixed and now that particular issue is over. but now a new one has started...haha of course. now it is a clicking when the clutch is depressed. Now the next part of the old car riddle must be solved. thanks for the help people. Link to comment Share on other sites More sharing options...
