frkkevin Posted October 18, 2007 Share Posted October 18, 2007 Wanted some kickpods to help with my staging.. no one makes them for our cars so I started to fab some up.. Half molds out and ready to connect to the factory panels.. http://img2.putfile.com/thumb/10/28920284019.jpg building the form.. http://img2.putfile.com/thumb/10/28920284313.jpg one wrapped.. http://img2.putfile.com/thumb/10/28920284329.jpg both wrapped and one partially glassed http://img2.putfile.com/thumb/10/28920284382.jpg a test fit of one.. http://img2.putfile.com/thumb/10/28920284443.jpg almost done glassing.. http://img2.putfile.com/thumb/10/28920284442.jpg http://img2.putfile.com/thumb/10/28920284435.jpg glass work done.. http://img2.putfile.com/thumb/10/28920284432.jpg ... now the pain of sanding to come.. have not decided on if im going to wrap them or paint them 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
greenchevette Posted October 18, 2007 Share Posted October 18, 2007 Real sweet man! Keep us posted! Link to comment Share on other sites More sharing options...
bms231 Posted October 18, 2007 Share Posted October 18, 2007 wrap b/c paint will get scuffed in 30 seconds once a girl sits in the car. o yea, i said it. they seem to be prone to scratching my shiznitz. Link to comment Share on other sites More sharing options...
frkkevin Posted October 18, 2007 Author Share Posted October 18, 2007 thats why i was swaying to wrapped.. i actually wanted to do white suede then do my inserts the same.. but being kickpods they would get dirty easy.. but suede does clean easy .. hmm 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
frkkevin Posted October 23, 2007 Author Share Posted October 23, 2007 quick wrap job, will be redone next month and done better.. wrapped in foam first to do a flush mount then re-wrapped in vinyl http://img2.putfile.com/thumb/10/29421065437.jpg 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
PGT Posted October 23, 2007 Share Posted October 23, 2007 mid only in the kick?? where's the tweeter? also....what size mids? Link to comment Share on other sites More sharing options...
frkkevin Posted October 23, 2007 Author Share Posted October 23, 2007 6.5" .. tweets will go in factory location on the doors.. depends on the speakers you run.. some perfer 4" from the mid.. other sets do better higher up on the A-pillar or top of the door 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
PGT Posted October 23, 2007 Share Posted October 23, 2007 are you serious? a midbass in the kick and the tweeter up high? good luck with that!! <---- would do a 4" and tweet in the kick and leave the six in the door for mo better imaging Link to comment Share on other sites More sharing options...
frkkevin Posted October 23, 2007 Author Share Posted October 23, 2007 should be fine, my main concern was the staging of the vocals.. with the pods it should be fine.. the tweets in the factory location give decent staging.. ive got an audiocontrol eqs ive still got to hook up.. the x-overs that came with this comp set have a slot for imaging tweets if i wanted to add a set later on.. 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
PGT Posted October 23, 2007 Share Posted October 23, 2007 the tweeters image better when they're close to the mids. look for threads started by 'msmith' - that's Manville from JL Audio. His build is documented and he experimented quite a bit. I did as well on my own build and the tweeters up high didn't do it for me. Link to comment Share on other sites More sharing options...
frkkevin Posted October 23, 2007 Author Share Posted October 23, 2007 just curious.. what color wires are the speakers? tried to find a diagram with no luck.. was going to tap into the wiring before it made it to the door but had no clue which wire is which.. was trying to research before i just started messing around with the dmm to find the right ones 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
biz77 Posted October 23, 2007 Share Posted October 23, 2007 Just run new wire through the loom and into the door. It isn't that bad. And if you want the tweets up high the stock location is just about the worst place to put them. The A-pillars would be a much better choice and it appears you have the fabrication skills to pull it off. You spent time equalizing the pathlength on the woofers and now you're going to muff it all up putting the tweeters in the stock locations? Link to comment Share on other sites More sharing options...
frkkevin Posted October 23, 2007 Author Share Posted October 23, 2007 its all test and tune.. some component sets sound better with tweeters in different locations.. that and ive got a lot of tuning to do with my EQ all new wiring will be run but i need to tap the stock wiring to go into the input of the audiocontrol.. after that its RCAs to a comp amp then out with new wiring 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
biz77 Posted October 23, 2007 Share Posted October 23, 2007 its all test and tune.. some component sets sound better with tweeters in different locations.. that and ive got a lot of tuning to do with my EQ all new wiring will be run but i need to tap the stock wiring to go into the input of the audiocontrol.. after that its RCAs to a comp amp then out with new wiring Gotcha on the oem wiring tap for the processor, but I still don't think you should rely on processing to overcome poor speaker placement. Tweeter placement is going to determine most of your spatial queues. General rules of thumb for placement (IMO): Place them as wide as you can, place them as far in front of you as you can, place them as high up as you can and place them as close as possible to partnering midrange drivers. Obviously you can't satisfy all the criteria so you must compromise. There is one obvious choice for your tweeters based on where you decided to mount your mids. I would personally start off with the tweeters in the kicks as it makes the most sense. By mounting them in the stock location you create possible and likely phasing problems (being so far away from the kickpanel mounted mids) and pathlength difference problems. Link to comment Share on other sites More sharing options...
frkkevin Posted October 24, 2007 Author Share Posted October 24, 2007 i see what your saying, ill just have to get some tape and tape the tweets to some different areas of the car until i hit the sweet spot .. kicks, upper a-pillar, lower a-pillar, and stock location started to flush mount.. http://img2.putfile.com/thumb/10/29523034016.jpg btw, anyone know about the wiring? didn't feel like pulling the door panels off to find out lol 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
s_nold Posted October 24, 2007 Share Posted October 24, 2007 Can you post a pic of the pod on the driver's side? I want to see how much room they take up. Link to comment Share on other sites More sharing options...
frkkevin Posted October 26, 2007 Author Share Posted October 26, 2007 Should have them in this weekend, ill take finished up pics you will lose you dead pedal completely just as an FYI 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
Dsfa Posted November 9, 2007 Share Posted November 9, 2007 Bump for updated pics . Link to comment Share on other sites More sharing options...
16psibrick Posted November 11, 2007 Share Posted November 11, 2007 looks good the only thing i would change is to mold out the floor mold a bit more, so you get more internal air space and a more blended look where is how i did mine: http://volvospeed.com/vs_forum/index.php?showtopic=45993&view=findpost&p=598922 posts 11 and 12 Link to comment Share on other sites More sharing options...
frkkevin Posted November 15, 2007 Author Share Posted November 15, 2007 Next year I'll be doing another set.. this was my first set and they came out alright. I'm going to mount the tweets in the A-pillars but I may go a different route next year. I'm thinking about putting the Mids in the doors and running a 1" Silk dome tweet and a 2" Mid/Tweet in a kickpod.. I'm not set on that yet but I'd like to run a 3-way Heres a few more pics since everyone is waiting lol.. I'll try and get a pic of the left pod with the speaker in it tomorrow. http://img2.putfile.com/thumb/11/31719340330.jpg http://img2.putfile.com/thumb/11/31719340372.jpg http://img2.putfile.com/thumb/11/31719330169.jpg http://img2.putfile.com/thumb/11/31719340373.jpg http://img2.putfile.com/thumb/11/31719340236.jpg http://img2.putfile.com/thumb/11/31719340219.jpg http://img2.putfile.com/thumb/11/31719340272.jpg http://img2.putfile.com/thumb/11/31719340274.jpg 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
frkkevin Posted November 16, 2007 Author Share Posted November 16, 2007 16psi.. hows the staging? looks good but seems like the drivers side is off axis a bit.. of course mine are too but i was just curious im going to throw up some idea and figure out what im going to do next.. might be better off getting a new set of kick panels.. but from who if anyone is interest in this pods lmk.. maybe we can work something.. these are my first set so they are not the best.. but next one will be way better now i have this under my belt 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
frkkevin Posted December 4, 2007 Author Share Posted December 4, 2007 bump for my dead thread kickpods are now for sale as well as the cdt components .. building new kickpods for my new components.. they don't fit in these 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
16psibrick Posted December 5, 2007 Share Posted December 5, 2007 stage is okay, the legacy isnt exactly the best interior for kicks: relatively short foot wells, large expanding center consoles and a relatively low dash... IMO if you want super height in the Legacy, you probably would need to go A pilalr tweets with TA... b Link to comment Share on other sites More sharing options...
